Gunnar Sommerlund
Marine Engineer
- Joined
- Jun 29, 2017
- Posts
- 32
- Reaction score
- Location
- Denmark
Note: This feature may not be available in some browsers.
Yes I'm very curious to know how it is suppose to work? What I did with the sail was no success and I ended up using an outboard engine on it.
hi, do you have and know windsurfing rigs? these cats came with a slender ss piece that locks into the mast track on the cat and screws into the standard flex joint [8 mm] of a windsurfing extension base .
then the 3 shrouds are attached strongly to the boom[boom must be very strongly attached to mast [clamp on boom of course] so it cannot slide down
main sheet attached at rear
ideally a slalom or cambered race sail is used
how did it go with a motor ?
cheers andrew
Well, with the motor it was fun. However on such a small boat i think electric would be better.
The previous picture where the sea rider i on the trailer, is how i managed to rig it. But it was no succes on water and rigging took way to long.
No i do not have dagger board. i have a custom tiller extension.
Then again, i did not manage to have much fun with it on water =(
