Hi Matiss,
if you haven't already, you might want to look/ask around in the french ocean racer ecosystem, mainly around Lorient. For example, there are
- folks doing foil control electronics as a service:
Système de contrôle de vol pour foilers - AUSTRAL Electronics https://austral-eng.com/controle-du-vol/ (i think i even saw an other one doing the same a while ago, but can't find it)
- plenty of designers and composite geeks with experience with foils in actual waves, including tricks like deformùation changing the angle of attack etc (recent article as an example:
LinkedIn https://lnkd.in/drPPjSWg )
- prototyping businesses specialising in performance parts, from infusion over autoclaves all the way up to tape-laying
SEAir Flying Boat - SEAir https://seair-boat.fr/ going quite military right now, and into rougher waters than the usual motor foilers, if that is where you are headed
If you aren't familiar with that scene,
www.tipandshaft.com might be a nice entry point, especially the job ads and announcements in the newsletter. You might actually consider posting there. It's cheap and you reach tons of fresh talent, some already with serious work under their belts.
BTW i might be curious about your pod. Is that something that could provide highly efficient thrust at 16kn, while also remaining in the safe 48V domain ? It's a bit sad for my purposes that solutions like rimdrivetechnology.nl top out at 22kW before going high-voltage.
Any plans for making it kick-up on debris impact ?
Cheers and best luck with your project!
