DaS Energy
Junior Member
- Joined
- Nov 17, 2010
- Posts
- 30
- Reaction score
- Location
- Gold Coast
Hello Yellowjacket.
Any thermal engine having a Carnot efficiency of 18% is a wonder it even goes.
Carnot. The loss of heat.
Force. Bar measurement of pressure.
Economy. Quantity of fuel usage.
All three apply to thermal engine.
Carnot. Submersed source of heating absorbs all heat to point of liquid boil.
Single cylinder one litre Diesel heat shed is 1200* Celsius.
Liquid may be held at 100* Celsius by twelve one litre takes of 100* Celsius.
Perimeter of heat sink leaks heat. Insulation limiting.
Force. CO2 gas at temperature of 100* Celsius has pressure of 7,000 bar.
CO2 gas at temperature of 32* Celsius has pressure of 64 bar.
Economy. Best Diesel 300 PSI compression heat expanded five times,1500 PSI or 100 bar pressure. Each combustion of one litre Diesel engine provides 100* Celsius heat to twelve separate litres of CO2. Each one litre of CO2 at 100* Celsius has pressure of 7,000 bar, or the forces of 700 Diesel engines. Heat from one Diesel engine combustion stroke provides to the same forces as 8400 Diesel engines.
Minimising sizing to complete the hot cold loop draws on refrigeration physics and the odd behaviour of CO2.
Containerised CO2 at 100* Celsius creates an internal Dry-Ice field.
Hidden inside the ice field is a cooling radiator, top and bottom accessing the outside.
Radiator top connected to outside expansion chamber. Radiator bottom connected to turbine suction hub.
Working. Cylinder having hot gas at top provides a downward force onto the liquid gas at bottom of cylinder. Liquid gas at force rotates the turbine runner till the liquid gas flash off to gas upon reaching the turbine exit expansion chamber entry point. Expansion cooled gas is then suction drawn through the Dry-Ice radiator, cooling the gas to liquid. Constant incoming of liquid gas ensures the cylinder never fully empties of liquid, thereby ensuring hydro turbine constant liquid pressure.
http://i1225.photobucket.com/albums/ee397/DaSEnergy/Untitled.png
Peter
Peter
