Sea Sled madness. It’s in my brain.
Discussion in 'Fiberglass and Composite Boat Building' started by DogCavalry, Nov 11, 2019.
  1. Mr Efficiency
    I don't think fuel burn would be an impediment, any more than a similarly powered "normal" boat, but the air bleeding back into the props might be a source of problems.
  2. DogCavalry
    Likes: 700, Points: 113
    DogCavalry I aim to misbehave.
    From contemporary reports, the entrained air passed out under the transom right in the middle. Twins had no problems. Where they used a single surface prop, they used a huge one. Miss Lakeside, seen here, has a 2' prop, on a 6' wide boat. 2-miss-lakeside-lake-tahoe-steven-lapkin.jpg
  3. Air Flite
    Likes: 34, Points: 13
    Air Flite Junior Member
    Thanks for the helpful information BB. I'm in touch with DC.
    fallguy and BlueBell like this.
  4. Air Flite
    Mr. E - I've read too much Sea Sled history to believe that the basic Sea Sled is not a competent boat in rough water. Sure, it's got its issues but that's not one of them. Now some Sleds were less than stellar in the ride quality department. I owned two of the modern Sleds (22' and 29') and they had their problems. Our 18' prototype in her final form was a sweetheart that ran like a charm over 2' bay chop, at any angle to the wind, at 30 mph and was safe in bigger seas at lower speeds.
    As I previously indicated, we got too cocky from our success with the 188 and made some bad assumptions with regard to the 270. One of the negative results was a ride in a chop that was unacceptably harsh. We were confident that we knew what to do to address that and a couple of other issues....but I've already explained why we shut down.
  5. DogCavalry
    The 22' and 29' sleds AirFlite refers to here are Salvatore Iannotti's builds. Those significantly deviated from Hickman's boats. Guy thought he knew better.
    AirFlite 's 18 footer was an absolute sweetheart. I've got a video I'm editing. Up soon. The boat he refers to that didn't work out as well is the larger one in his pictures. Changes to Hickman's original design, not enough testing.
  6. DogCavalry
    That's quite a lot of prop, for the size of transom.
    fallguy likes this.
  7. Air Flite
    We never ran a formal fuel consumption test on the 270, as we decided it wasn't ready for prime time before we got to that point. I used her for my own recreation quite extensively and achieved roughly 1.5 miles per gallon cruising at 38 mph. This was with 1994 225 Mercs with carbs., not nearly as smooth running and fuel efficient as todays monster injected, often supercharged OBs.
    While the 270 had a strong hole shot, she was not happy cruising at speeds under 32 mph. The sweet spot for cruising was 34-40 mph. We believe that we built in too much lift forward and too little aft. We were confident that we had the specific solution to that..... One thing that was fun with both boats was running them on the flats. At 45 mph, the 270 would run in 18" of water, the 188 in 10" -12". I had many much smaller craft run aground trying to follow the 270 across the flats into Cabbage Key's Bar and Restaurant.
  8. DogCavalry
    Got the superstructure going back on.
  9. BlueBell
    Likes: 415, Points: 83
    BlueBell "Whatever..."
    Is that light I see at the end of the tunnel?!
    DogCavalry and cracked_ribs like this.
  10. DogCavalry
    20210130_190220.jpg 20210130_190230.jpg 20210130_185644.jpg 20210130_185321.jpg 20210130_182534.jpg 20210130_182447.jpg
    Like eating sand. Slow and painful. But here is more progress on Serenity.
  11. BlueBell
    Huge progress!
    Nice photos!
    Good work.
    DogCavalry likes this.
  12. DogCavalry
    It looks fragile, but I was doing chinups off the forward beam, and its canted 15° forward. 240 pounds in my work gear. A reasonable test.
    cracked_ribs and Air Flite like this.
  13. cracked_ribs
    Likes: 78, Points: 18
    cracked_ribs Junior Member
    Big visible changes! Not much more satisfying than that!
  14. Mr Efficiency
    I see your "slave" is still on the job DC, what a honey !
  15. DogCavalry
  1. massandspace
  2. fredrosse
  3. Tiger51
  4. cy fishburn
  5. Jordan Epstein
  6. chowdan
  7. andysailor
  8. jjhamm22
  9. Ian Pope
  10. irishglasspar
