Sea Sled madness. It’s in my brain.
Discussion in 'Fiberglass and Composite Boat Building' started by DogCavalry, Nov 11, 2019.
  1. DogCavalry
    Likes: 700, Points: 113
    DogCavalry I aim to misbehave.
    20210105_210730.jpg 20210105_210721.jpg 20210105_210708.jpg 20210105_210650.jpg 20210105_210632.jpg 20210105_210620.jpg
    I can install the glassed panels across these frames now. At least no drips inside anymore.
  2. Cajunpockettunnel
    Likes: 136, Points: 43
    Cajunpockettunnel Senior Member
    Moving right along! You're getting it done!
  3. DogCavalry
    Maybe wrap the boat directly in Tyvek. Well, just enough clearance for condensation on the Tyvek to trickle out the bottom.
  4. DogCavalry
    Anybody know anything about heater control valves on an Astrovan?
  5. BlueBell
    Likes: 415, Points: 83
    BlueBell "Whatever..."
    I did some research.
    Is it leaking?
    Looks like the cores and the valves clog-up often.
    Also, prone to vacuum issues, cracks etc.
    Have you considered removing the core,
    back flushing it, by-passing the valve, and replacing.
    You'd have heat for the winter.
    Either block off in the summer or remove.
    Did you replace the lower rad hose already?
    DogCavalry likes this.
  6. DogCavalry
    I'd like to bypass it, but it's the 6 port. I can identify 4 of the 6 hoses. The last 2 are mysterious.
  7. DogCavalry
    All my wordwork has been disassembled and driven across town to dry in a friends basement. It was getting speckled with mold.
  8. cracked_ribs
    Likes: 78, Points: 18
    cracked_ribs Junior Member
    Oh man, how frustrating. It's been a wet fall and winter, all right.
  9. DogCavalry
    Yes. Yes it has.
  10. fallguy
    fallguy Senior Member
    Can you bring in some class 5 gravel and push the water away?
  11. DogCavalry
    I'm in the low spot, so it would take a sandbag berm to keep out the streams coming from every direction. What I hope to do is epoxy coat the superstructure in about a week. Reinstall it. Put on the roof beams and roof, then put on a second tarp directly over the boat, and maybe tape that to the hull sides. I can work inside that double envelope until dry weather. Maybe.
    Reality check please.
  12. fallguy
    If you read back a ways, I told you to use 2" pink polystyrene to enhance the build and keep it drier.
  13. DogCavalry
    I remember
  14. fallguy
    It is relatively inexpensive and you can use it for flotation foam after winter season. Bury it under pour foam, or cut in sheets of it. It'll save you money on pour foam.
    I realize the challenge to you and I empathize, sometimes patience is the only magic
    My water problems take a different form
  15. DogCavalry
    Everything in the house for a week. Now epoxy coated and curing.
    Stofferaus and BlueBell like this.
  1. massandspace
  2. fredrosse
  3. Tiger51
  4. cy fishburn
  5. Jordan Epstein
  6. chowdan
  7. andysailor
  8. jjhamm22
  9. Ian Pope
  10. irishglasspar
