Sea Sled madness. It’s in my brain.
Discussion in 'Fiberglass and Composite Boat Building' started by DogCavalry, Nov 11, 2019.
  1. DogCavalry
    Likes: 1,823, Points: 113
    DogCavalry Senior Member
    I need to rent some load cells.
  2. comfisherman
    Likes: 548, Points: 113, Legacy Rep: 10
    comfisherman Senior Member
    Travel lift usually had pretty good scales.
    Gauges neat the driving station (although most are remote now) usually have good weights.
    DogCavalry likes this.
  3. DogCavalry
    I had forgotten. When the lift splashed her down last time the scale on one strap was out, so we didn't get a good read. Coming out this time, I forgot.
  4. baeckmo
    Likes: 917, Points: 113, Legacy Rep: 1165
    baeckmo Hydrodynamics
    So what were the readings from the three functioning cells then?
    BlueBell likes this.
  5. DogCavalry
    I don't recall. It was 3 years ago. But on the way out I will defintely take note.
  6. DogCavalry
    Damn. Getting off the barnacle bases w/o flaying the epoxy off the hull is an endless process.
  7. BlueBell
    Likes: 1,305, Points: 113
    YUP. Not a lot of fun is it?
  8. baeckmo
    Umhum....painting with antifouling is slightly less unfun I'd say.....
  9. DogCavalry
    That is my hope.
    fallguy likes this.
  10. DogCavalry
  11. fallguy
    Likes: 2,040, Points: 123, Legacy Rep: 10
    I’m not sure whether I see the broken seam properly. If it is over the fillet, I’d say the quick look would suggest insufficient tabbing. Lotsa loading there and you’d need probably about a minimum of 75 oz of glass tabbing there, plus the glass on each surface. And that is a gut hunch is all. 100 might be closer.
    I think the forum has lost a great contributor in @rxcomposite . Not sure, but he’d be able to give the best laminate plan if he is able.
    I wasn’t gonna tell you, but I threw away a set of 4 load cells mounted on 8” C channel. Might have cost $200 to ship to you, bit had no buyer here for them.
  12. DogCavalry
    I believe you are correct. I had substantisl mechanical connection there, with screws and cleats etc. The fillet and tabbing were supposed to manage water. But the mechanical side allowed about 1/16" motion. Enough to break the tabbing and fillet. Darn.
    What is up with @rxcomposite ?
  13. BlueBell
    That's really unfortunate.
    Great weather to grind it wide open and let it dry. Acetone.
    You may want to build up some layers around your bolting points too
    over and above the transom reinforcement layers.
    Too bad those didn't go on during the build... next time.
    I don't think you need rxcomposite type direction, this is a pretty easy fix.
  14. DogCavalry
    Fairing compound going on. Chine flats were really coarse. 17oz biax plus epoxy. No fairing. Might give a tiny increase in Vmax.
  15. baeckmo
    I would'nt worry much about fairing, just smoothen the highest ridges and get a good af on (the new silicon based seem to be good and are environmentally fine). But the chine should be sharp and with a horizontal surface, ca 50 mm wide.
    fallguy likes this.
    1. Darkzillicon
    2. Danmax
    3. Dillusion
    4. Tungsten
    5. valvebounce
    6. Runhammar
    7. fallguy
    8. massandspace
    9. fredrosse
    10. Tiger51
