Sea Sled madness. It’s in my brain.
Discussion in 'Fiberglass and Composite Boat Building' started by DogCavalry, Nov 11, 2019.
  1. DogCavalry
    Likes: 1,830, Points: 113
    DogCavalry Senior Member
    Yes, I think.
  2. BlueBell
    Likes: 1,306, Points: 113
    Right, check with the Boss first, smart.
  3. Will Gilmore
    Likes: 534, Points: 113
    Will Gilmore Senior Member
    It is my profession, besides bee keeping and farming.
    I would be happy to work with you on a concept. I will have to charge for a completed finished design, though.
    When BlueBell asked if I'd be interested, I started looking into a little of the sea sled history and I feel a 1920s Art Deco look would be cool.
    -Will
    BlueBell and bajansailor like this.
  4. BlueBell
    Sorry Will, my mistake. I didn't realize you earned a living as an artist.
    I was just looking for ideas that might relieve the flatness of John's two slabs.
    Keep in mind John, you don't have to do the same design on each side.
    One will never see both sides at once. Fun.
  5. Will Gilmore
    I'm happy to give you ideas and a quick concept sketch. Just give me some idea of what you'd like.
    -Will
    BlueBell likes this.
  6. Will Gilmore
    I was just reading about Harriet Frishmuth, and the hood ornaments she sculpted in the 1920s.
    [​IMG] and thought something like an art deco design, in keeping with the design era of the sea sled, would be super peachy keen.
    -Will
  7. BlueBell
    John, any ideas?
  8. DogCavalry
    I carry heavy objects. Anne decides. I will get her into the convo. Small budget though.
    I am considering going down a prop size for a long trip in Serenity to the boatyard. Still getting fairly regular overheats, so the trip to the yard. Anyway, my logic is smaller prop turns at higher rpm for the same power demand. More water flow through the pump.
    @gonzo
    @baeckmo ?
  9. DogCavalry
  10. Will Gilmore
    No problem. I'm here if you want to discuss it further.
    -Will
  11. DogCavalry
    At the travel lift. 2 hours 15 minutes averaging
    21 knots
    3900 rpm
    43 liters per hour
    Engine solid at 156°f/69°c
  12. DogCavalry
  13. gonzo
    Likes: 2,401, Points: 123, Legacy Rep: 2031
    If the engine is running below the rated RPM, it is overloaded will run hotter. The water flow will be lower too, which compounds the problem.
    DogCavalry likes this.
  14. DogCavalry
    Yeah. That's what I figured. Thanks.
  15. baeckmo
    Likes: 924, Points: 113, Legacy Rep: 1165
    baeckmo Hydrodynamics
    The nominal wot consumption is ~88 l/h, and your 43 liters correspond well with propeller power at 3900 rpm, which tells us you have been running at about 50 % power. That's not too bad for the speed and the bottom condition during the trip, and we still don't know her displacement......
    1. Darkzillicon
    2. Danmax
    3. Dillusion
    4. Tungsten
    5. valvebounce
    6. Runhammar
    7. fallguy
    8. massandspace
    9. fredrosse
    10. Tiger51
