Sea Sled madness. It’s in my brain.
Discussion in 'Fiberglass and Composite Boat Building' started by DogCavalry, Nov 11, 2019.
  1. BlueBell
    Likes: 420, Points: 83
    BlueBell "Whatever..."
    Thanks FallGuy, but I have nothing to add.
    Good progress John.
    Carry-on.
    DogCavalry likes this.
  2. DogCavalry
    Likes: 711, Points: 113
    DogCavalry I aim to misbehave.
    Replying to Fallguy over in Dynel:
    The transom is glued and screwed with PL premium. In hindsite I wish I'd used epoxy. Its 2⅛ thick, and I allowed for a lot of extra glass there. After all, I plan to hang 2 heavy outboards there.
    The deck and cabin roof will be working surfaces. Like a workshop floor, so I'm sure there will occasionally be 2 carpenters, a table saw, and a load of lumber on the roof. I mean to build it to the same scantlings as the hull bottom.
  3. fallguy
    Likes: 783, Points: 123, Legacy Rep: 10
    fallguy Senior Member
    hmmm, well, I would not use the bottom scantlings
    U need to use plywood and glass and traction paint you can repair easily.
    The bottom is designed for hydraulics. The work surfaces are designed for maintenance.
    the way this is done is you ply and glass and prime in one color and two coat traction paint and when the traction paint is going; the primer is revealed and u know it is time to recoat
  4. fallguy
    Traction paint on walking surfaces. This is a single coat of paint.
    You don't want a lot of weight up high; so you won't be glassing the same unless you switch to foam cores which are not as stiff..best way is a good frame and 1/2" plywood.. You can glass the bottom. A lot depends on if camber.
    Use Roseburg Marine ply..pretty cheap; only okay if fully encapsulated; leave no edges exposed...epoxy sealing them is not enough, they really need glass if outside, I can take some pictures and show you why..
  6. DogCavalry
    Ad Hoc and BlueBell like this.
  7. DogCavalry
    With the rapidly evolving economic fallout to COVID-19, I suspect I'm about to suffer some delays.
    BlueBell likes this.
  8. Ad Hoc
    Likes: 860, Points: 113, Legacy Rep: 2488
    Supply chain.. or just a lack of enthusiasm?
    I like the product placements btw :D
  9. DogCavalry
    Well, I'm a poor working carpenter punching well above my weight here. I've been counting on side jobs to bring in the extra money to get this done. But that might not be a thing for the next year.
  10. BlueBell
    Adversity can be the mother of invention.
    But you gotta look hard, you may need a magnifying glass...
  11. DogCavalry
    Not being able to make extra money to build my own boat is a problem most of the world would love to have right now.
  12. fallguy
    You, sir, are a great human. If I were you, I would try to get the hull closed up. Little bit at a time.
    Imagine being someone in a poor country facing this pandemic.
    bajansailor, DogCavalry and BlueBell like this.
  13. DogCavalry
    It breaks my heart to think about.
  14. BlueBell
    Wow, almost 20 pages on one man's obsession.
    I love it. You go man.
    Imagine how much that beautiful wooden hull is going to dry up in this Summer's sunshine.
    bajansailor and DogCavalry like this.
  15. DogCavalry
    Got that angle covered. Already laying awake at night imagining it.
  1. massandspace
  2. fredrosse
  3. Tiger51
  4. cy fishburn
  5. Jordan Epstein
  6. chowdan
  7. andysailor
  8. jjhamm22
  9. Ian Pope
  10. irishglasspar
