Yes, you are right. The whole thing came off as a unit. I was surprised to find oil in there. Obviously I will have to replace that oil. Do you know what kind of oil it is?Yes, the question is wether the seven vanes seen from the nozzle side in the earlier set of pictures are intact or damaged at the leading edges (facing the impeller outlet). I don't think the center screw should have to be touched; it may hold the impeller to the shaft. Check if it rotates with the shaft. The complete housing aft of the impeller should come out as a unit.
Here are the pics? it appears to look good everywhere to me. Nothing appears damaged or excessively worn.
