sea chest sizing
Discussion in 'Boat Design' started by AAM, Feb 13, 2025.
  1. AAM
    AAM Junior Member
    Hello everyone , How can I determine a rectangular sea chest size for a crew boat 30 m ?
  2. BlueBell
    Likes: 1,298, Points: 113
    By how much stuff you need to put in it.
  3. AAM
    AAM Junior Member
    30
  4. BlueBell
    That was easy. Just make it 30 then.
  5. AAM
    AAM Junior Member
    Sorry I read it staff , my mistake
    What do you mean by stuff?
    Likes: 2,018, Points: 123, Legacy Rep: 10
    Demand. You need to calculate demand on the chest.
  7. kapnD
    Likes: 570, Points: 113, Legacy Rep: 40
    kapnD Senior Member
    Allow for future additional demands and possible marine growth/clogging.
    Overkill is your best friend for any raw water intake.
    I see far too many sea chests that do not use strainers, big mistake.
  8. BlueBell
  9. AAM
    AAM Junior Member
    Can you be more specific?
    I tried A=Q/v to calculate the cross sectional area but I don't know if it's right or wrong?,
    And I am not sure of the range of the velocity ?
  10. AAM
    AAM Junior Member
    I read that the strainer should be at least 1.5 times the area of the inlet valve
    But I am not sure how to calculate the volume of the sea chest or based on what ?
  11. gonzo
    Likes: 2,367, Points: 123, Legacy Rep: 2031
    The needs for everything that will get water from the intake is what you need to calculate. There is no way to help you unless you get that value. Also, the location and spacing of the intakes have to assure that a large intake with high velocity is not starving a small one. Strainers should be calculated based on the total area of the openings, and type. For example, a strainer with small round holes will have less flow than one with longitudinal vanes, even though they both have the same free area.
    fallguy likes this.
