screws in plastic SOT for side carry handles spinning. (see pics)
Discussion in 'Boat Design' started by Squidly-Diddly, Dec 24, 2022.
  1. Squidly-Diddly
    Likes: 187, Points: 63, Legacy Rep: 304
    Squidly-Diddly Senior Member
    Trying to replace busted side carry handles on Tarpon 16i. Just spins, and center hatch is too small and my arms to big to get to anything from the inside. Seems to be factory install. Any tips?
    Will I end up mounting handles on fresh deck surface fore and aft of existing screws? How to make new mounts strong enough to handling carrying the big SOT with one strong hand? Some sort of butterfly? I assume thats what the factory mounts are. Maybe drill about 1/8" bit close to edge of screw to hold in place to back out, then a dab of sealant if needed? 20221224_200926[1].jpg 20221224_200856[1].jpg
  2. philSweet
    Likes: 621, Points: 113, Legacy Rep: 1082
    philSweet Senior Member
  3. Kayakmarathon
    Likes: 49, Points: 28, Legacy Rep: 10
    Kayakmarathon Senior Member
    I would use a Dremel high speed drill with a flush cut tip to remove the screw head. Recover the nut / anchor with flexible grabbers and a $30 wireless endoscope. Examine the inside mounting surface to determine how the bolt was held in place while the bolt was turned. Remove the remaining bolt from the nut. Find new bolt. Make new nylon web grips. Assemble.
  4. Squidly-Diddly
    I'm thinking more like this with 3 or more long legs to spread load over the fairly weak and thin plastic. Its a 70lbs+ boat most of that load will be on just one of the two connection points when I use almost all my strength to heave it up or down. https://www.amazon.com/T-K-Excellen...jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
    But main issue is getting the old screws to unscrew.
  5. Squidly-Diddly
    $30 Scope ordered, didn't know they'd gotten that cheap! :) If I cut the screwhead off wont I still be stuck with screw shaft in whatever its screwed into and it will still be just spinning so no way to drill out the shaft? It was the fabric of the old handle that broke and I've got new handles, so I'm hoping to re-use factory connection method. I'm thinking once I get the scope I'll be able to rig a gig (probably grab with long nosed vise grips) to stop the backside from spinning and go from there.
  6. BlueBell
    Likes: 1,233, Points: 113
    Have you considered epoxying the screw, both sides, and drilling it out?
    Or, easier still, take a grinder to the head...
    What's an SOT?
  7. Tops
    Likes: 122, Points: 43
    Tops Senior Member
    Sit-On-Top kayak
    BlueBell likes this.
  8. BlueBell
    Not to be confused with a SOF.
    Tops likes this.
  9. Squidly-Diddly
    not expoxy but I was thinking of cutting the sides of the head flat so it would become like a two sided nut I could grab with Vise-Grips then drill out.
    I wasn't thinking clearly before and now understand that if I cut the head off whatever the shaft is screwed into should fall into the hull.
    Be nice to know what is the default factory way they do these handles on these SOTs where the shapes and locations make it tricky to access the back-side. I guess it might be some boat-specific factory trick gig to hold the anchor in place. Waiting on Scope to show up.
  10. Tops
    Tops Senior Member
    It might work to pull up on the bit of strap and unscrew slowly, possibly with a small cat's paw levering under the screw head and against the hull.
    Or any other SO_ three letter acronymn... :)
  11. BlueBell
    Like SOR?
  12. Squidly-Diddly
    sorta tried that, might try again.
  13. BlueBell
    And taking a grinder to the head...?
    If you hit it right it won't spin.
  14. BlueBell
    Like SOH
