Scows in the Mini Transat
Frazzle
New Member
Joined
Sep 17, 2026
Posts
3
Reaction score
Location
England
Hi this is my first post here. I want to learn more about what makes the Mini Transat scow yachts so fast and can those benefits translate to the larger IMOCAs.
it is mostly a downwind race, the scow bow allows for more sail area at the penalty of a bow shape that does not do as well going upwind as a pointed bow.
It is a shame that they developed into boats that are so specialized. The early boats were a joy to sail in any conditions.
If
If the limitation is length, then the fastest yacht is an extreme scow (Skene, "Elements of Yacht Design", 1906)—I’d have to look up the specific page, as I’m quoting from memory, but it might be page 3.
Widening the bow was the only remaining option in the quest for more power.
On the other hand, getting the bow out of the water early is a good idea, and "early" could mean, for instance, a Froude number of 0.50.
And so we have gone (2014-) from absurdly sharp bows to absurdly wide bows— from one extreme to another.
That is true on downwind sailing, and upwind in up to moderate conditions.
It really comes down to material strength. Adding more hull surface area adds weight and faces diminishing returns in terms of sail carrying ability. The stronger the hull material, the less added weight and the further you can push the box. Once you get to the point where global strength issues are dominating hull structural weight (as opposed to ding resistance and point load dispersal concerns), then the specific strength of the material that is used for the structure's design strongly drives the optimal hull form. The difference between Comanche and Napoleon's L'Orient hull shapes come down to material strength and exploiting it to lower the VCG. You can literally use a parametric hull optimizer to get either by adjusting the allowable specific strengths of hull spar and sail materials.
Improved spar and sail materials shake out as taller rigs and trend towards lower heel angles for best performance. The heel angle strongly affects midsection shape.
The last generation of non-foiling IMOCAs had greatly increased bow volumes before foils became the more effective way to carry more sail power and heel less. The bow volumes are less now and the bows are designed around very different constraints on the foilers. Scow bows need significant heel angles to pay off their weight penalty.
Contrary to popular belief, scow bows are excellent for working to windward in most conditions. But they can have problems in large seas. For about a century, scows held all manner of sailing speed records including the absolute monohull record, centerboard record, and closed course records. Exactly why they took 100 years to appear in ocean racers probably has more to do with technology developments. These have enabled a massive increase in average sail power. Things like weather routing, autopilots, and advanced sail control systems - along with a change in the culture of ocean racing and those who participate in it - finally overcame the inertia. But the odd rebel was out there on the big water racing in scows - A famous turboed E-Scow won the Miami - Key West race several times and embarrassed a whole raft of multihulls like Tornados and Nacras.
I agree that scows and sharpies do well to windward when heeled. I think that when conditions are extreme, they don't do as well as a hull with finer lines forward.
Savitsky (1973) "Resistance of Transom-Stern Craft in the pre-planing regime"
Savitsky (1973) was interpreted quite literally to mean "let's build light sailboats with sharp bows"—though it could also be interpreted as "let's get the bow out of the water early," implying bows capable of withstanding the massive leverage exerted by the sail force.
To me, that is the interesting underlying theme here.
Then there is the age-old racing mentality: the "mine is bigger" contest—hoisting even more sail for longer, moving from an astronomical amount of canvas to a truly sidereal one.
Meanwhile, others are crossing oceans while rolling incessantly—mainsail down, two headsails up—a practice unheard of in the 19th century.
Somewhere in this mad world, there has to be a middle ground.
In other words
it is very interesting to rethink the 0.40–0.60 Froude range and break free from the Delft polynomial in that intermediate zone—which can be termed "pre-planing" or "semi-displacement."
And that is exactly what we are seeing.
Note the use of the word "scow."
"With its scow [?] hull, very light displacement and large sail area, the JPK 1050 marks a break with traditional IRC boat design"
There are two distinct stories intertwined here.
A wider bow—though it doesn't need to be gigantic—and essentially a scaled-down Class 40.
Yes, that represents the cutting edge of performance sailing today.
And you get better numbers and much more comfort by making it smaller.
(Class 40)
Judith Rich Harris, "The Nurture Assumption"
Children bring what's new.
The "Scow" designs from the Mini Transat have spread like wildfire.
(And now, cruising yachts will follow suit. An eternal return.)
Regarding the "scow" bow—and the general trend toward wider bows—there are two distinct stories and sets of interests at play:
A) a hull capable of carrying even more sail—between the era of the crazy canting keels and the next step: flying on foils
B) pitch control and a rapid transition from displacement mode to planing mode
If the bow is nowhere near the water,does it really matter?
yacht-100158093-80714b5baf6641482a1a31fecbcaf906
Yes
That is exactly what the future holds:
1) high-performance racing yachts flying along, and
2) "dinosaur" boats—rolling heavily with a massive mast, an unused mainsail stowed low, and two headsails flown on twin poles—whose crews either rush to a hotel upon reaching the Caribbean, fed up with the boat, or give up on crossing the Atlantic once they hit the Canary Islands... continuing on like this until the dinosaurs go extinct.
And the funniest thing is that those of us crying out in the wilderness for a middle ground will be taken for madmen.
The world of high-level competitive sailing hasn't been driven by madness since 1850 simply because of the quest for speed—where sailing at 20 knots versus 5 knots is a reasonable goal—but rather by the pursuit of that tiny margin that secures a win: my yacht sails at 5.1 knots and yours at 5; mine at 10.1 and yours at 10; mine at 20.2 and yours at 20.
That is the madness of the competitive sailing world.
On the other hand, the cruising world should be defined by functionality and comfort.
And there is nothing more comfortable than a small, sporty sailboat designed with safety, functionality, and comfort in mind: he crosses the Atlantic enjoying his sporty sailboat while she flies there—it is the ultimate in comfort and minimizes the risk of divorce.
In fact, this is already happening in France. My proposal follows this trend, but instead of a 3 to 3.5 tons boat and costing 240,000 to 300,000 euros, it envisions a 1-ton WindSurf Board —a true "people's boat" (or "Volksboat")—that could take the place of, for instance, the glorious Albin Vega 27.
