What I want to do is compare a contemporary pedal/paddle drive commonly used in the MR.340 race with a pedal driven horizontal oscillating fin located under the GC of the craft.
The issue is to match the power to weight ratio of the models to a solo marathon racer. Too light or heavy a model tells me nothing.
The MR340 looks like a crazy race! What amazes me is how relatively close the record times are amongst solo vs teams, and by paddle vs pedal.
340 miles covered in under a 40 hours by a solo paddler or pedaler is 8.6 miles/hour. I assume your baseline of 100w and 260# figures means you are looking at a solo vessel. What are the nominal continous boat speeds discounting rest breaks and current? FWIW, the crew that just broke the Missouri River Speed Record averaged 3.94 mph. I think their speed picked up by 1-2 mph after they got past all the dams in South Dakota.
The formula for a 'Froude scaled' power conversion uses the formula
P model = P full x (1/scale factor)^3.5. The thread
Scaling power?(with replies by
@Ad Hoc) goes there. Becasue it discounts viscous drag, the results are exceedingly low. One would imagine boats in the MR340 are at SL of ~0.8 - 1.2, with skin friction making up over 50% of total drag. Does that sound correct?
Do a search on model boat building, and you come across rules of thumb of 1.5-3w/lb to push a displacement model at hull speed. Nothing specific about the model scale, but applied to your scenario, that
might be applicable.
How long is your boat gonna be? How about 20' LWL? A 1/5 scale model will have 4' LWL. Model displacement will be 6.4#. 1.5w/lb x 6.4# = 9.6w. Halve that or double it. Quarter that or quadruple it. Model up both a 'proven' paddle drive and your horizontal fin drive. Put in a PWM controller and measure power consumption at a range of SL's for both drives in the same hull model. If there is going to be signifigant improvement in going to a different drive, I'd think it would show up. If your hull shape and the model for the existing paddle drive is scaled to an existing boat with known performance, you could draw better conclusions. Seems like a fun project!
Also, the video
@portacruise links to is worth a look. The model may be 'clunky', but the efficiency of air props over putting the drive in water is marked - see screen snip below. There is mention of MIT's
Decavitator as well.
