Scales on graphs
Discussion in 'All Things Boats & Boating' started by gonzo, Aug 16, 2017.
  1. gonzo
    Likes: 2,094, Points: 123, Legacy Rep: 2031
    On a different thread there has been some misunderstandings related to scales. A couple of members questioned why it makes a difference whether a scale is linear or logarithmic. I would like to discuss scale types and their advantages.
  2. hoytedow
    I am still trying to figure out how to use my slide rule. :(
  3. hoytedow
    At least it doesn't leave a carbon footprint. o_O
  4. hoytedow
    Seriously, I usually get a better perspective with a linear graph.
  5. Mr Efficiency
    It depends on what is intended to be depicted. If the horizontal scale is half a mile long, and the vertical six inches high, some compression is required for it to be visually interpreted.
  6. hoytedow
    True, but I don't see compressed as logarithmic. Please correct me if I am misunderstanding.
  7. Mr Efficiency
    If you want to give a fairly detailed picture of recent trends, set against a much broader picture of long term ones, then the scale has to be uneven, to be seen at a glance. So long as the scale change is clear, all good.
  8. hoytedow
    As long as the distortion is explained and not used to deceive, I am okay with it.
  9. Mr Efficiency
    Of course, When I see a graph showing, e.g., how the Australian dollar has risen sharply, and it looks like it is on a zig-zag upward course at a 45 degree angle, it becomes rather less dramatic when you notice the vertical scale started at 75 cents US and peaks at 77 cents. Misleading.
  10. gonzo
    Logarithmic scales can be convenient. For example, the cooling of an object is a logarithmic function. However, it can be linearized with a logarithmic scale, which may make it easier to use.
  11. TANSL
    Likes: 855, Points: 123, Legacy Rep: 300
    Logarithmic scales can be necessary, essential. To understand why you just have to read post # 7 of Mr Efficiency. That is the correct explanation. The rest are misconceptions.
  12. hoytedow
    Mercator projection is another good example of that.
  13. TANSL
    A lorithmic function can be represented on axes with linear scales. It has nothing to do the form of the function with the scale that is adopted to represent it.
    A straight line can be represented in logarithmic axes and in some cases there will be no choice but to do so.
    Do not confuse concepts.
  14. gonzo
    Do you understand how to linearize a graph? We do this with experimental data on a daily basis.
  15. TANSL
    Who are "we"?. You only can do it with experimental data?. Is it not possible to do it with data obtained from reality?.
    What a strange and most disturbing science!
