Saphira 70 cat, twin masted, well conceived
Discussion in 'Multihulls' started by brian eiland, Dec 14, 2025.
  1. brian eiland
    Likes: 257, Points: 93, Legacy Rep: 1903
    brian eiland Senior Member
    bajansailor and montero like this.
  2. brian eiland
    https://www.chriswhitedesigns.com/images/pdf/saphira.pdf
    The 70' hulls are for speed and sea-kindliness, not space. The beam, weight and sail area are similar to a performance cat in the 55' to 60' range. Saphira has covered approximately 25,000 miles over her six seasons and has the parts and the maintenance to continue cruising the world's oceans.
    Construction: The vessel was built by Goetz Composities in Bristol, Rhode Island, a company known for its decades of high quality construction, including Americas Cup boats. All of the structural elements were built from vacuum bagged epoxy pre-preg carbon fiber cured at 200 degrees F under vacuum and cored with high temperature "Core-Cell" foam. This ensures the lightest, strongest and most durable laminate possible.
    All exterior surfaces are spray painted with AwlGrip linear polyurethane coating.
    Weight was a key consideration so, for example, instead of painting the inside surfaces of the hulls which would have required many pounds of fairing compound to get a smooth surface, the boat has "Whisper Wall." This is a light material that looks great, provides insulation for sound and heat, as well as providing space for wiring.
    Crossbeams are built of uni-directional pre-preg carbon fiber with foam cored epoxy/carbon fibre bulkheads.
    Extensive Finite Element Analysis structural modelling and final engineering was done by SDK Structures, also known for their work on high tech racing and Americas Cup boats. Interior joinerwork and floorboards are all cored panels to provide stiffness at low weight with lovely veneer for good looks.
    Propulsion: Starboard & Port: Volvo D2-75 diesels with saildrives (April 2024 Engine Hours: Port - 1547; Starboard 1576)
    Recent engine service included replacement of mixing elbow and oil pans.
    Dual instrument panels with tachometer and engine monitoring gauges and alarms.
    Dual Racor primary fuel filters to allow for switching.
    Secondary fuel filters on the engines.
    Dual "ZF Micro Commander" electronic single lever engine controls mounted at pilothouse inside helm and outside in the forward cockpit.
    Three blade bronze folding type propellers by FlexOFold
    Steering:
    Rudder blades are carbon fiber, high performance hydrofoil section with carbon fiber rudder stocks turning in JP3 spherical rudder bearings.
    Custom carbon composite radial drives
    All Harken roller bearing sheaves leading Dyneema steering cable
    Exit Carbon Composites wheel in cockpit
    Engine Rooms & Watermaker Cabin
    One critical aspect of the design was to make maintenance easier for the owners. The aft part of each hull has full standing headroom engine rooms. Literally, you can walk around the engine. This makes maintenance, like checking the oil or cleaning the sea water strainers, which is rarely easy on sailboats, easy to do. It is the same with a watermaker ... sure, you can get to the filters when you have to crawl under a berth or into a small space, but will you do so as often as you should? Saphira may be the only cruising sailboat where the watermaker has its own cabin with full standing headroom.
    Carbon Mast and Booms
    Carbon fiber masts and booms are from Southern Spars, New Zealand
    Carbon fiber roller furling mandrel is from Offshore Spars
    The airfoil shaped tapered freestanding masts turn in JP3 spherical bearings at the deck and the bilge levels.
    Masts rotate relative to the boat using the mainsheets, so they can rotate 180 degrees each way without breaking anything. In fact, they were made to rotate 270 degrees just to make sure they were safe. If there is ever a concern that the boat is dangerously overpowered, you just blow off the mainsheets and the sails "flag to the wind."
    Masts rotate forty degrees port and starboard relative to the boom for sail shape and this is controlled from the cockpit via a hydraulic cylinder.
    Masthead light, masthead VHF, wind instruments
    There is one main halyard and one spare on each mast. Halyard locks - full hoist position and the 1,2&3 reef points.
    All controls are in the cockpit. Sails are furled with Bamar hydraulic roller furling on mandrels above the boom, so the operator can "see" the roll at all times.
    Sails are "vang sheeted" with a large Harken hydraulic cylinder. No topping lift needed. No block & tackle at the end of the main boom, which just adds friction and many more feet of line that has to run freely to depower.
    Sails
    2 x Square Top Mainsails, Doyle Sails, 2023. Radial head dacron, two ply leech. Super durable offshore construction.
    Running Rigging
    Dyneema halyards and control lines. Low stretch sheets (2022, 2024)
    Deck Hardware
    Winches:
    2 x Harken #70 Performa 2 speed electric winches
    2 x Harken #60 Performa 2 speed electric winches
    Spinlock and Karver rope clutches
    Daggerboards
    Two cored carbon fiber asymmetric "hi lift" daggerboards
    Up and down haul controls lead to cockpit
    Collision Bulkheads
    Each hull has a "false" bow section plus two collision bulkheads forward.
    There are multiple watertight compartments throughout the boat.
    Electrical:
    American Power Products - High output, low rpm, 140amp 24V alternators
    2 Wakespeed 500 regulators
    24-volt circuit breaker panel with redundant voltage and amp meters.
    3 x Lithionics 300 amp hour, 24V batteries each with a separate with BMS, 900 amp hours total
    2 x Lithionics 12V engine start batteries
    Battery monitors
    LED strip lighting in multiple places (bilges) to aid maintenance
    LED lighting throughout the boat, including red night lighting within the pilothouse
    Solar Power:
    2.1 Kilowatt output in 17 Solbian Solar Panels with individual Genasun solar charge controllers. Located on pilothouse top where they are largely free of shading.
    AC System
    Victron Energy Phoenix Inverter, 24Vdc/120Vac Output 60Hz
    Shore Power: Li3 Multi-input &output Lithium Battery Charger, 100-240Vac/50-60Hz input, 29.2Vdc/300W output
    AC outlets are installed in the following places. (1) each head, (1) galley, (1) hightop, (2) starboard-side main salon, (1) each workbench/dressing area, (1) nav. Station, (1) each stateroom AC locker, (1) port side of pilothouse settee, (1) each engine room, (1)
    Tanks
    (2) 150 gallon diesel fuel tanks each with deck fill, vent, shut off and gauge
    Fuel transfer pump
    (2) 75 gallon water tanks each with deck fill, vent and gauge
    (1) water transfer system using house water pump
    Watermaker
    14gph Spectra 24v Cape Horn Extreme located in its own "cabin" - full standing headroom for ease of maintenance.
    Navigation & Electronics
    B&G AIS
    B&G Chartplotter - 16 inch Nav station unit
    B&G Chartplotter - 12 inch Cockpit station unit
    B&G Chartplotter - 9 inch Owner's berth unit
    Depth - 2 sounding units (one on each hull, one forward scanning)
    B&G Halon Radar
    VHF - B&G with Digital Selective Calling (DSC)
    VHF - Standard Horizon handheld with Digital Selective Calling (DSC)
    B&G Wind
    B&G Autopilot
    2 x Autopilot drive units (one on each rudder)
    ICOM IC-M802 SSB radio
    Starlink and Iridium GO Satellite Communications
    Hailer PA Horn, 2020
    Hull and Deck Ventilation:
    (13) Deck hatches, all Lewmar Ocean Series. Accommodation area hatches are equipped with Ocean Air roller shade/screens.
    (6) opening portlights with clear plexi windows, three in each outboard hull side
    An opening port is located adjacent to each double berth
    Cowl vents in engine rooms and in anchor locker
    (14) Hella fans, (2) main salon, (1) each head, (3) each stateroom, (2) each forward cabin,
    Air Conditioning and Heating:
    2 "window style" units, 5500btu in each master stateroom, connect directly to shore power at 110V
    Webasto AirTop EVO 55 diesel air heater
    Rails and Lifelines:
    Custom fabricated carbon fiber stanchions with dyneema lifelines.
    Custom fabricated polished SS pushpits
    Integral swim step on rudders and transoms
    Swim ladder - use "toy locker" ladder and hang on transom step
    Anchor Handling:
    Dual bow anchor rollers enable two anchors to be easily used at the same time.
    (2) Muir Storm VR3500, 24VDC, 1500W, 316 Stainless Steel windlass. (1) rope/chain gypsy (1) chain only
    Self-bailing lockers for self stowing chain and rode.
    Bow Thruster:
    Side Power Model SRVP80 185T-24V, Cockpit control, inside joy stick
    Anchors:
    (2) Rocna 40Kg anchors, (1) with 265' 10mm chain (2023), (1) 25' chain, 250' nylon rode
    Danforth stern anchor, 25' chain, 150' nylon rode
    Salt water washdown
    Cleats and Docklines
    (8) 14" docking cleats, (2) bow, (2) stern, (2) aft springline, (2) forward springline
    Two 14" large size, mooring cleats
    (6) braided ¾" docking lines, (2) long (≈50'), (4) short (≈30')
    (4) 1¼ " 3 strand nylon docking/mooring lines - variouslengths
    Navigation Lights
    Lopo LED lights, Stern, steaming, port/starboard, masthead and masthead strobe
    Exterior Lighting
    Transom and aft deck LEDs
    Aft dinghy floodlights
    Deck lights (inboard side of both masts)
    Interior
    All cabinetry is foam core with veneer
    Varnished red birch interior with fiddles and trim
    Teak and holly laminate soles in accommodation spaces
    Semi-gloss polyurethane finish in accommodation areas
    Main Salon
    Varnished wood table, with fold-out to seat 10.
    Aft settee seats have partitioned stowage beneath via lift out covers in the seat top.
    Forward settees lift for easy access to batteries, electrical, solar, inverters - plus storage.
    Pilot House Navigation Station
    B&G 16" display (multiple programable displays); ZF electronic gear shift/throttle control
    Autopilot controls: B&G (various screens), port controller (buttons), starboard controller (joystick)
    Ritchie compass, B&G Triton (?) full displays
    5" Czone screen with access to all electrical controls
    Large "L-shaped" chart table with full size chart drawer beneath and dedicated printer
    One file drawers and one miscellaneous drawer
    Electrical outlet for laptop computers, etc.
    Maretron monitor (all vessels sensor) with multiple screens that are user configured
    Bilge Pumps:
    Each hull is divided into 3 major compartments that are watertight above the static waterline to cotrol flooding in event of collision or other calamity. In addition SAPHIRA is positively buoyant and cannot sink under any circumstances. Appropriate bilge pumps are located in each hull compartment.
    An "Arid Bilge System" is used to pull out the little remaining water that normal bilge pumps cannot remove ensuring very dry bilges throughout the boat.
    Bow Nets
    High strength Dyneema knotless net.
    Forward Cockpit
    Carbon wheel at foward end of spacious L90" x W95" cockpit with full forward visibility
    All controls within easy reach: instruments, winches, clutches, line reelers, halyard locks, throttles, anchors
    Seats are L86" x W20" with cushions, great for entertaining, sleeping
    Folding aluminium, dining table with canvas storage bag in forward cockpit
    Tensioned awning with removable posts forward, so it can be rolled up and stowed in integral zippered poach
    Aft Deck
    Aft "tensioned" awning. Stamoid heavy vinyl coated fabric, AR-60 polycarbonate window material (11/22)
    Dinghy hoist and dinghy tie downs built into the aft deck
    Four large seat lockers along the forward side of aft deck for stowage:
    (1) miscellaneous cleaning supplies
    (1) Brownie electric hookah storage with battery, one dive tank to fill 2 spare ait mini tanks, 5 gallon gas
    (1) BBQ storage with additional space
    (3) 20lb fiberglass LPG cylinders with direct venting outside of boat.
    Custom carbon, glass and screen doors into main Salon
    Galley
    Force 10 four burner propane stove with automatic temperature control oven and broiler
    Xintex remote solenoid propane shut-off switch
    Whirlpool microwave oven
    Galley sink is house sized - deep double bowl polished stainless steel with strainers set flush into a counter top
    Hot and cold pressurized water delivered by single lever mixer
    Automatic, instantaneous hotwater dispenser
    Separate Whale galley footpump for hands free, fresh water
    Ample drawers, lockers and shelves for storage. Built in trash and recycling containers
    Refrigeration
    Galley, front opening, Isotherm Cruise 195 Classic w/wood panel to match interior
    Galley, drawer opening, Isotherm Drawer 160 Light top fridge/bottom freezer w/wood 3/4" panel to match interior
    Coffee table, top opening, Engel MT80 12/24VDC - 110/120VAC fridge-freezer w/wood panels to match interior.
    Midship Cabins
    Port side is set up as a working area with tool storage and 66" x 19" work surface. (2) Large hanging lockers. Tool drawers and bags.
    Many tools including some that are unusual and, at times, indepensable.
    Starboard side is a dressing area with clothing storage, hanging lockers, drawers, as well as access to electric panel.
    Master Staterooms
    Each hull has a sleeping cabin amidships with king sized berth that can be oriented fore and aft or side to side.
    Air mattresses for light weight and to be easy to handle.
    Clothing storage under the berth and outboard. Additional storage at forward end. Small shelves for head aft position.
    Heads - Port & Starboard
    Tecma X-light carbon fiber toilet with Tecma Silence macerator pump system, plumbed to holding tanks with valves for overboard discharge, as well as pump out.
    Heads are equipped with polished stainless steel sink with hot/cold pressure water via a mixer.
    Laminate countertops and stowage lockers beneath including laundry bin.
    Full walk-in shower with electric sump pumps.
    Hot Water Heater
    PrecisionTemp Showermate M-500 EC Hot Water Heater
    Outside Shower
    A hot and cold water pressurized rinse station is installed on the starboard hull transom boarding platform.
    Fresh Water Washdown
    Outlet for hose in forward cockpit.
    Workbench (port hull)
    Drawers and lockers below for tool and parts storage. Lockers above for additional storage.
    Lockers outboard for stowage of larger tools and electrical, sail repair, paint and miscellaneous other supplies.
    Exterior Finish
    The entire above water line exterior of the boat is spray painted with linear polyurethane, custom color mixed by Awlgrip to match Benjamin Moore "Niagra Falls" blue. White on deck is Awlcraft Matterhorn White with non-skid on walking areas.
    Hull Rub Rail
    An external rub rail with solid metal cap.
  3. brian eiland
    I did find it interesting that in their pursuit of the best windward performance they chose to use "Two cored carbon fiber asymmetric "hi lift" daggerboards"
    I chose asymmetric boards as well, but kick-up centerboards.
    Skip Johnson and montero like this.
