Drawing Translation
Discussion in 'Boat Design' started by Go5Go, Apr 8, 2004.
  1. Go5Go
    Go5Go Junior Member
    I am working with a shafting plan out of the Netherlands and on the shaft tapers they have the call out "conus 1:10" or "conus 1:12". Is this the same as a taper, or is it applied as a taper were over 10mm there would be 1mm of taper, 2mm overall on the shaft, or does it mean more like a truncated cone where there will be only 1mm difference overall on the shaft?
    I don't trust the scaling as I am working with a scan of the original drawing.
    Don't have access to the actual shaft ends at this point.
    Thank you for your assistance in advance.
    Regards,
  2. guest
    guest Guest
    I would try contact the designer if it is an "modern" design and an existing design office. Otherwise it should not be difficult to check the orriginal drawing.
    By the way: Working from a scanned drawing and building a boat without paying the designer would NOT be the way to go. This should NOT be endorsed! I do not think this forum should help with this kind of illigal practices. I think a designer should get proprly paid for the desings he or she has spend a lot of time and efford making.
  3. Go5Go
    Go5Go Junior Member
    It is not illegal what I am doing.. We have been contracted by the owner of the vessel to do Naval Architecture. The original drawings are in dutch/German from DIANA.. Just thought with the number persons viewing maybe some one here could translate faster than getting a responce from DIANA.. I will write them monday from the office for clarification.
    The original drawings are stored up some place... Easier to post a message than go rummaging..
    Cheers.
  4. SailDesign
    Likes: 198, Points: 73, Legacy Rep: 650
    Go5Go, I think what you have there is correctly called a "pitch" in English. The 1:10 would taper 1mm in every 10mm, in section. In other words, that would apply to the surface, not the diameter.
    Better to use the original designer's opinion, however....
    Steve
