Your first sentence was a bit confusing, but...
Cleaning the surface of anything you're applying something over prior to sanding is good idea if needed, it's not always required though. And it also depends on the grit you're using, the finer the grit the more likely surface cleaning will help. 400 grit isn't removing much material, so cleaning helps a great deal, 36 grit is removing a good deal of material and flinging it elsewhere, so cleaning doesn't help that much.
It also depends on what surface contaminants you're trying to get rid of. If the item was waxed two years ago there is little, and more likely no wax left on the surface, but if you're redoing an old bilge with decades of gunk built up in it, you may need to clean it several times before you start sanding.
Cleaning after sanding is a different process, but again, isn't always required. For low viscosity paints that will fisheye at just the thought of contamination, it can help a great deal. After grinding a surface with 36 grit you most likely don't need to clean it other than sweeping, wiping and/or vacuuming the surface.
Cleaning with a surface prep product (not acetone) after sanding with fine grit paper is a good idea. Trying to solvent clean a surface after 36 grit is more difficult, you end up smearing dust and contaminants around until you've filled the bottom of the sanding scratches with dust and debris that dries like mud on the bottom of a dry lake bed.
Although cleaning a small area with acetone might work if you do it properly, just wiping some around on the surface doesn't do anything. You need to use two rags, one with wet with acetone and a clean dry one to pick up the still wet acetone from the surface. Since acetone dries so fast you don't end up picking up much gunk off the surface, you just smear it around. Products designed for cleaning don't evaporate as quickly so you have more time to remove them from the surface after they've dissolved and picked up whatever stuff was there.
Epoxy can blush leaving a wax like film on the surface, this needs to be cleaned thoroughly with soap and water to remove it, solvents won't do it. Then the use a coarse grit to prep the surface.
Always use the coarsest grit possible for a better bond, 80 grit will work, but 36 grit is better. This all depends on exactly what you're putting on the surface though, Imron won't look good over 36 grit, but a laminate over 36 grit will bond much better.
