30 foot sailing cat. Roof is to be 4metres across and 4.5 fore and aft. Covers cabin, cockpit and gantry for dinghy. 4 laminated 45mm beams across the boat. Roof also supported by cabin walls.
There will be a steel structure holding up the roof where the mainsheet traveller is going and where the gantry for dinghy is going.
Have a mold made up. see attached photo(this is half the mold). Due to various reasons, i want to go down the following track. Was going to get professionals to have a foam core fibreglass roof but the cost is really blowing out
Layer of fibreglass cloth followed by whole sheets(2400*1200mm) of 4mm marine plywood across the boat(Athwartship) followed by 300mm wide strips of 9mm marine plywood fore and aft followed by 6mm foam core followed by 4mm sheets across the boat, another layer(???) of cloth and then gelcoat.
Going to use lengths of timber to batten down the plywood for each layer
Maximum curving fore and aft is 140mm over 2000mm (stern half is nearly flat) and across the boat, 115mm over 2 metres
Doable? Have read lots of threads on compound curving but as a novice I am confused as ever.
Read the gougeon book on compound curve. Couldn't really understand the data on figure 25-29. Longitudal bending seemed very little.
Any advice on how to go about it? Is there a difference is bending across the plywood sheet as compared to along the sheet? Alot of forums mentioned 3mm as the first layers
Someone mentioned not to soak the plywood before fitting as it will stiffen the board too much.
Also use ot epoxy and thicknesser when putting on the boards?
Thanks
Thanks
