Sailcut CAD
Discussion in 'Sailboats' started by J_Hapster, Dec 22, 2025.
Tags:
  1. J_Hapster
    Likes: 2, Points: 3
    J_Hapster Junior Member
    Hello, I just started using Sailcut CAD, very cool tool. But I was only able to print a PDF of the layout patterns. I tried several ways to export to a DXF but it doesn't make any files at all. Any ideas what I may be doing wrong? I want to upload to AutoCAD to make bigger pattern prints.
  2. TANSL
    Welcome to the forum, @J_Hapster. I'm not familiar with Sailcut CAD, but I was wondering if you could create the drawing directly in AutoCAD. Anyway, if you'd like, please upload the PDF file here so I can see what I can do with it. I imagine a DXF file would work just as well as a DWG file.
  3. gonzo
    Likes: 2,297, Points: 123, Legacy Rep: 2031
  4. Tops
    Likes: 130, Points: 43
    Tops Senior Member
  5. Tops
    Tops Senior Member
    I forgot something...
    When you save to the default directory [C:\Program Files (x86)\Sailcut CAD] , the files disappear...?!?
    If you force the files to save into another folder it should be fine.
  6. Boat Design Net Moderator
    Likes: 199, Points: 43, Legacy Rep: 1004
    Just ran into something similar on a test computer last week - Windows 11 may redirect files that programs try to save into protected directories such as Program Files (x86) to a "Virtual Store" -- if this happens, check C:\Users\Your-Username\AppData\Local\VirtualStore\Program Files (x86).
    Tops likes this.
  7. J_Hapster
    Likes: 2, Points: 3
    When saving, I'm told by the computer the default drive is not permitted to be written to, so I use another folder on my data drive, that's where nothing shows up. So I searched the hard drive for the file to see if it saved elsewhere but nothing. I installed the program as administrator in windows 10. Perhaps if I reinstall it as my user name, I can save to the default directory since it's not letting me choose another folder... WINDOWS!!!!
  8. J_Hapster
    Likes: 2, Points: 3
  9. J_Hapster
    Likes: 2, Points: 3
    Sailcut calculates the complex curves to form the sail airfoil shape, very cool tool. So once I get a .dxf I can bring the shapes into AutoCAD
  10. Tops
    Tops Senior Member
    My computer behaved as described by @Boat Design Net Moderator , the first set of files ending up into the user virtual location (not directly visible but I could search for and find them) but the purposely-redirected files were OK (visible/useable) in a desktop folder as shown in the screenshots.
    Maybe try writing the files to the same drive as the installed software but a different folder?
  11. J_Hapster
    Likes: 2, Points: 3
    I'll try it later today, I'm making a flying Gennaker for my O'Day 17, fun project
  12. J_Hapster
    Likes: 2, Points: 3
    No joy yet. I've tried installing the program directly to my data hard drive. but I get the same results of no files. I did get several test.dxf 's that showed up in a search as a shortcut and an internet shortcut. but no actual file., see screenshot
  13. J_Hapster
    Likes: 2, Points: 3
    Do you know of any database of Sailcut CAD files for sail types? I'm working out a new auto furling flying Gennaker for my O'Day 17 that I can single hand. I've tried a few searches but nothing. Either that or some other sail database that has the proportions to set for a Gennaker. So far I've got one made up in Sailcut CAD mostly by intuition and a few good articles on sail design, but very little real data. I am an Engineer so my intuition is usually pretty good but sail design is a new area for me I'm exploring. Thanks: J_Hapster
  14. Tops
    Tops Senior Member
    Sounds interesting. Are you going to have a roller furler for the jib and another 'less fractional' stay and furler for the gennaker?
  15. J_Hapster
    Likes: 2, Points: 3
    It will be a flying Gennaker, with a bottom up furler, I'm making it on my 3D printer. I have a suitable block to mount up near the masthead, although I do see a lot of fractional spinnakers on O'day daysailers. I'm going for a sail to primarily use on light wind days.
