Sail Area vs Keel Area - Stability Calculation
Discussion in 'Hydrodynamics and Aerodynamics' started by Dabrownone, May 28, 2012.
  1. DCockey
    Likes: 201, Points: 63, Legacy Rep: 1485
    DCockey Senior Member
    More than that.
    Either the relative sizes and shapes fo the sail rig and hull would have to be such that the a force on the keel that matches the force of the wind on the rig/sails and the heeling moment of the force from the current on the keel matches the heeling moment of the force of the wind on the rig/sails
    - or -
    The boat would have to be constrained so that it could not move sideways but could pivot and the heeling moment of the force from the current on the keel matches the heeling moment of the force of the wind on the rig/sails.
  2. HakimKlunker
    Likes: 9, Points: 18, Legacy Rep: 146
    HakimKlunker Andreas der Juengere
    Who wants a boat like that?
    I call this a case of mathematical diarrhoea
  3. BobBill
    Likes: 12, Points: 18, Legacy Rep: 157
    Location: Minnesotan wakes up daily, in SE MN, a good start,
    BobBill Senior Member
    Dab, I thank you for your inquiry, and the others for contributions, as I learned.
    But, Dabrownone, if static, a waste of time, to me, or, as one noted, self-abuse...real world...learn from these boyos.
  4. BobBill
    Very kewl link, very kewl, Daq. Thanks.
  5. dougfrolich
    Likes: 21, Points: 28, Legacy Rep: 225
    dougfrolich Senior Member
    I would recomend reading Areo-Hydrodynamics and the Performance of Sailing Yachts
    by Fabio Fossati
    In section- 6.4 Equilibrium under sail - estimating the surface area of hull appendages
    is a very nice article that goes back to the "spirit" of the origonal post.
    My $.02 worth.
  6. Paul B
    Paul B Previous Member
    Not really.
    That section is more like the "spirit" of the diagram daiquiri has posted.
    The OP is intent on proving that a large enough surface area under the waterline will somehow stop a boat from heeling.
    These are two very different things.
  7. TeddyDiver
    Likes: 112, Points: 73, Legacy Rep: 1650
    TeddyDiver Gollywobbler
    And the reality makes it just opposite way.. more keel area, more heeling, less lateral area (no keel) less heeling :D
  8. Petros
    Likes: 139, Points: 63, Legacy Rep: 1593
    Petros Senior Member
    That just shows why mathamatitions working in any other field need to be supervised by people in that field.
  9. dougfrolich
    In the "spirit" meaning here is a fine preliminary math model for first estimates.
    Can we be more pedantic?
  10. BobBill
    Why would ya? Seems to be pointless enterprise to begin with. No offense intended, but not practical, therefore pedantic, perhaps? Still, my numb head picked up some needed material via the out takes, regarding major sail plan change...
  11. RBauer
    RBauer New Member
    EF2F8B3B-FB91-4DA4-95B7-A8D5EA30454B.jpeg 1F7891B2-BCA0-4D71-9793-33E42D96397F.jpeg 924334D7-14CF-4175-B3D5-571E1D336E38.jpeg I need help to determine the weighted needed in the keel for my RC model of this Wianno Senior. It is a scratch build 1”= 1’
  12. DCockey
    Do you want you model to float on the same waterline as the full size boat? If so the total weight of the model to be scaled appropriately from the total weight of the full size boat. The total weights to be scaled as the dimensional scale ratio cubed. So for a model built to a scale of 1" = 1' or a dimensional scale ratio of 1/12 the weight of the model needs to be 1/1728 of the weight of the boat.
    My understanding is scale model boats intended for sailing frequently have keels which are deeper than the original boats keel.
  13. Howlandwoodworks
    Howlandwoodworks John Howland
    If you were to Heave-To you would create a similar scenario but from a different set of circumstances. Sail configuration and angle of attack could create the stall over the keel you are looking for without creating a Frankenstein boat.
  1. RumnCoke
  2. Rich_Hamer
  3. Yull
  4. Manfred.pech
  5. andysailor
  6. CocoonCruisers
  7. mustafaumu sarac
  8. revintage
  9. Dolfiman
  10. Dolfiman
