JavaFoil Presentations
Paul
I am not sure if it has come up on this thread before but it could be worthwhile playing with JavaFoil if you want to get into low speed foil design. It is nice software to use and gives good results. I have checked its output against test data from Selig et al and it is favourable.
I have used JavaFoil quite a lot to develop shapes for low Re# water propellers and the results have been good. Rick W.
Here are a few JavaFoil presentations on this subject thread addressing my 'sail interaction' (slot effect) contentions:
http://boatdesign.net/forums/showpost.php?p=89766&postcount=148
http://www.boatdesign.net/forums/showpost.php?p=89921&postcount=151
_______________________________________________________________
Here's another posting referencing some of these images...from a
mast-aft subject thread
Originally Posted by tspeer said:
Nobody yet in this thread has offered up any quantitative estimate as to the performance advantages of their design over a conventional sloop or cutter rig designed to the same requirements, or shown how there's any weight savings in the structure. I can understand the desire to simplify sail handling with roller furling staysails. But any improvement in performance is by definition a quantitative issue, not a qualitative one.
Hello again Tom. Once again I must beg off on a ‘quantitative’ reply to the advantages of the headsail arrangement on my mast aft rig concept. I believe just as with the
rigging load questions, a straight-forward quantitative calculation as to the superiority of the efficiency of the headsail over the mainsail may well be an incalculable quantity from a purely mathematical standpoint. So I have to rely on a variety of observations gathered from history, from pass designer’s applications, from current theorist, from real time sailor’s experiences, etc.
So I will present a few of those observations:
1) Lets begin with a ‘pictorial’ example. Rick Loheed recently posted these
images here, “I found a post that had a reference to JavaFoil, Martin Hepperle's 'relatively simple' inviscid foil analysis program that will do multi-element airfoils. It is great for illustration purposes here. Clearly it shows the affect of the whole system- actually, as a cascade of foils. Further Aft foils must have more incidence- but when incidence is added, they help increase circulation around the whole system, increasing the forward foils effectiveness by inducing more incidence and accelerating more mass about the whole mess".
Which sail looks most effective at driving you forward.
2) Another JavaFoil analysis by
Rick here, “Here is a comparison using Javafoil of a simple 15% camber (pretty high lift) 40% max camber location Jib/main combination arbitrarily loaded to near Max CL, and a 20% Clark 'Y' wingmast shape based on methods from Tom Speer's wingmast paper. For an input Aspect ratio of 10 for each case, this simulation shows a Max Cl of 2.11 for the main jib combo readily achieved for the combination, whereas the wingmast gets to a fairly typical Cl of 1.2 max”
3) Excerpted from aerodynamicist and North Sails consultant Paul Bogataj’s paper, “How Sails Work”
http://www.northsailsod.com/articles/article6-1.html
‘Sails in Combination’, “Each sail by itself is much simpler than the combination of a foresail and mainsail as in the sloop rig. The sails are operating so close to each other that they both have significant interaction with the other. The most interesting feature of this is that the two sails together produce more force to pull the boat than the sum of their forces if they were each alone.
The foresail of a sloop rig operates in the upwash of the mainsail. The wind as far upstream as the luff of a genoa is influenced by the upwash created by the mainsail. Hence, a jib or genoa in front of a mainsail has a higher flow angle than it otherwise would have by itself, causing an increase in the amount of force that the forward sail produces. So, while the mainsail is experiencing detrimental interference from the foresail, the foresail benefits from the interference of the mainsail. Notice that more air is directed around the curved leeward side of the foresail. This causes higher velocity (lower pressure) and more force. The net result is that the total force of the two-sail system is increased, with the foresail gaining more than the mainsail loses”
4) Its been some 40 years ago that I did extensive study of some of the classic sailing boat design books, but I can distinctly remember how there was applied a ‘performance factor’ to the headsail of 1,3 to 1.5 more effective than its actual sail area when computing the CE of the sail plan. So even though the theory was not thoroughly understood at the time, real time observations came into the equation.
5) Redcooprs was talking of the subject under the ‘Fraction Rig’ discussion (www), “However, the design of sailforms is very much a practical nature. In terms of sailing, the feel is that our jib supplies the driving power - and wind tunnel tests also show that it has a very large Cl compared to the main. The main on the other hand, is very responsible for the righting moment and general tuning of the boat.”
...item #24
http://www.boatdesign.net/forums/showpost.php?p=110983&postcount=24
