cluttonfred
Senior Member
- Joined
- Mar 2, 2014
- Messages
- 101
- Reaction score
- 26
- Location
- United States
Don Elliott on Storm Petrel continued
"Wed Feb 7, 2001 6:49am
STORM PETREL STUDY NO 3
In the last article on Storm Petrel we saw that sometimes designers don't agree on where boat floatation should be located. In this article we'll compare those different locations and see what affect they have on the boat.
We decided in the last article that the best way to evaluate the different locations is to see how these locations affect the boat. We then made a list of what we want the flotation to do for us. Here's the list from the last article on what we would like to have.
1. What we want is the flotation material not to encroach on our needed space.
2. If capsized we want the boat to right itself and not be stuck upside down.
3. If holed or flooded we want to be able to plug the hole and bail the boat.
4. We want the boat to be able to sail or motor on in any condition.
5. We want to correct the problem in the least amount of time or better yet not to have it occur at all.
Is it possible to have all of these things? That will be the subject of our next article on Storm Petrel.
For item number 1: placing the flotation at the rear on the bottom is no problem but in the cabin area it would as there is very little space even to turn over in your sleep (about 24 inches (60 cm) of height in the cabin). If flotation is placed on the floor it would intrude on the cabin space, we don't want that.
See the following sketch for item number 2. On that sketch you can see that if the boat capsized completely and didn't right itself on its own it would be much harder to turn the boat back upright if the flotation were located on the bottom. If it were at the deck level (view A) wave action alone would most likely right the boat, with no effort on your part. If it didn't right on it own, with the flotation at deck level it would be a snap to roll it upright.
Item 3, this is a condition where for one reason or another the boat become flooded due to a hull puncture or simply water somehow entering the cabin. This is a more complex problem and will require a separate article in itself. We'll cover this later.
Item 4 the ability to sail in any condition is no problem; both locations will allow us to do that; even if Storm Petrel was unlucky enough to be flooded completely.
Item 5; correct the problem quickly or preventing it in the first place is closely tied to item number 3, so it will be discussed at the same time, that is, in the next article.
The last question; can we have everything in the list without compromising anything else? In the final article on flotation you will see that with careful design we can. Don"
