Rudder stock for supported type
Discussion in 'Boat Design' started by S17665, Apr 14, 2016.
  1. S17665
    S17665 Designer
    Hi Guys ,
    could anyone suggest to me a company or a tips for a rudder stock for a supported on keel ? I have doubts about the bottom bearing.
    The lenght of the boat is 50 ft thank you so much in advance.
  2. PAR
    Likes: 505, Points: 93, Legacy Rep: 3967
    There are several companies that could help as well as design firms, though you'll need to provide a lot more information. Typically, the make, model and year would be a start, plus any special attributes, such as keel/rudder types that might have been offered on that particular model and a more defined explanation about your heel fitting doubts.
  3. S17665
    S17665 Designer
    Hi PAR , the boat is a simple canalboat with a symmetrical divergent airfoil (fish tail ) section for the rudder.The material of the boat is Midsteel and the hull is entirely flat on bottom.It is a preliminary design.
  4. PAR
    Post lines or photos, as your description isn't especially effective, possibly a translation issue.
  5. S17665
    S17665 Designer
    The stern and rudder is like this one on the right
    I need a company that supplies rudder stocks
  6. gonzo
    Likes: 2,118, Points: 123, Legacy Rep: 2031
    Usually you can buy rudder stock from any company that sells shafts. For short pieces, like what you seem to need, sometimes cut-offs are available at a discount. You can also buy a broken shaft and use the middle.
