Steve_uk
- Oct 19, 2022
- Messages
- 9
- UK
Hi,
We have sustained some damage to one of our rudders on our Woods Flica catamaran.
We are in marina that has mud berths and it would seem that there is something hard in the mud.
As the tide drys, sometimes with small waves, our rudder has be bashing onto it and now has about 200mm missing from the bottom. Only found this when lifted out recently.
The rudder has a 40 diameter stainless steel tube and is plywood sheathed in GRP. Maximum thickness about 40mm. Don't know what the internal build up is except the level of the bottom of the stock.
I am asking for some advice on how to repair it insitu since I cannot drop it due to the length of the stock tube and expense of having to hire a crane to lift the boat high enough to remove.
Thinking of using some foam core bonded to the bottom of the plywood and then sheathing with epoxy and cloth to a thickness of 6 to 8mm. Maybe add some Kevlar cloth to add strength and protection when drying out? This would be with about a 400mm overlap onto the undamaged plywood and sheathing.
Any advice welcome please.
Drawing below - orange is missing section!
