Rudder question
Discussion in 'Boat Design' started by woodboat, Nov 12, 2003.
  1. woodboat
    woodboat Senior Member
    Parameters: light boat, 6000 Lbs, 28 FT in lenght with a single inboard. Current approximate max speed 28 Knts. What speed advantage, if any, could be gained by moving the rudder from behind the prop and using a twin rudder design flanking the prop on either side?
  2. mmd
    Likes: 16, Points: 0, Legacy Rep: 309
    mmd Senior Member
    None to negative, IMHO.
  3. woodboat
    Thanks. I asked because I saw an early high performance chris, inboard with twin rudders. It was marketed as high performance for the time. Thinking that the rudder is in the "thrust" that the drag would be more there then out of this wash. I am still hoping that someone has tried personnally and has some hard data. Again thanks for the thoughts :)
