Rudder Location
Discussion in 'Sailboats' started by SuperPiper, Jun 19, 2003.
  1. SuperPiper
    Likes: 6, Points: 18, Legacy Rep: 58
    SuperPiper Men With Little Boats . .
    I sail a pocket-cruiser with a transom-mounted rudder. I am about to modify the pintle and gudgeon hardware to incorporate boarding handles/ladder (every component must have multiple functions to justify its weight, eh). This modification will move the rudder about 2-1/2" outboard of the transom.
    However, I recently saw what I believe was a C&C 25 (?). It had a recess in the transom for the rudder. The rudder was actually a few inches inboard of the transom. I have also noticed that the recent fleet of blue-water racers have evolved so that the rudder(s) are located under the hull just forward of the transom.
    What are the advantages/disadvantages of having the rudder under the hull? Is there a critical dimension from the keel to the rudder? Is there a disadvantage to having the rudder further aft of the keel?
    I doubt that my modification will have any impact on how the tub sails. But, I am curious.
  2. SailDesign
    Likes: 151, Points: 73, Legacy Rep: 650
    Quote: "What are the advantages/disadvantages of having the rudder under the hull? "
    You won't break it if you back into something, and it can't ventilate if over-rotated. Those would be the two major advantages. Disadvantages? You have a new hole in the hull that wouldn't be there if you transom-mounted it.
  3. Guest
    Guest Guest
    If your modified rudder extends farther aft of its pivot point, (the vertical line drawn through the pintles) there will be more force opposing you on the tiller.
    Tim Dunn
  4. SuperPiper
    Weather Helm
    The pintles are also moving outboard. The balance on the rudder should not change.
    But here is an observation: the tiller gets heavy on this round little boat as she heels and loads up. She tracks OK with the rudder midships but it seems that the rudder is sharing some of the lateral resistance with the keel. This is not quite the same as weather helm is it?
  5. Hushinish
    Hushinish Junior Member
    my rudder is mounted on the stem, it works wonderfully.
  6. gonzo
    Likes: 1,718, Points: 123, Legacy Rep: 2031
    It will move the center of lateral resistance aft. This should decrease the effort on the tiller and reduce maneuverability. The extra space gives you the opportunity of balancing the rudder to take out some of the weather helm.
  7. Lew Morris
    Likes: 4, Points: 18, Legacy Rep: 92
    Lew Morris Industrial Designer
    I just fabricated a new kick-up rudder for my old McGregor Venture 21. Our launch facilities are sling only and the water at minus tide is only about twenty inches ... hence the kick-up feature.
    Rather than just radius the corners off of a slab (like the original) I decided to build a foam/glass version using the NACA 0012 airfoil (another Boatdesign Forum topic) . I also added an inch of counter-balance to the leading edge (projecting forward of the pintle axis) at the same time.
    WHAT A DIFFERENCE! Low speed maneuvering performance is incredible, and weather helm, and tiller pressure are (or seem) to be much reduced.
  8. Guest
    Guest Guest
    So Gonzo, if I relocate the rudder further aft, then the centre of lateral resistance will also move aft?
    Does this mean that I may be able to order a roachy, full-battened mainsail without upsetting the balance of the boat?
    Wow! I'm getting a bulge in my forsail. . .
