Rubbing out the Nibs in Awlgrip
Discussion in 'Fiberglass and Composite Boat Building' started by TripleCrownNC, Apr 29, 2008.
  1. Kaptin-Jer
    Likes: 18, Points: 0, Legacy Rep: 206
    Kaptin-Jer Semi-Pro
    Your right. Boat week-end. Finally installed 2 bilge pumps. Would you believe I had this boat in the water for two years and never had a pump on it?? I'm a smart sailor:rolleyes: and I got a guy to rebuild the tranny for$300.00. We are getting there. Jim, ever hear from your friends regarding the Electric?
    I asked the reducer question before and didn't get an answer. Are you using the correct reducer? The primer and brush topcoat reducer cans both look exactly the same. It's easy to get them mixed up. I usually don't reduce my Primer. What number is on the reducer can that you are using. I hope it's T0005 or T0031, You can get by with T0031 for your Primer too. Down here we stick to T0031 most of the year. Epoxy-- you can't mix up the primer epoxy with the top coat epoxy. Like Jim just said. Rule out everything before you chew the reps head off. If it is the paint I would make them repaint it for you. Your not a pro, but it cost you your time, sandpaper, cleaning stuff, and the consultant fees you have to pay Jim and I.:p
  2. the1much
    Likes: 44, Points: 0, Legacy Rep: 696
    the1much hippie dreams
    ya,,,sorry Kapt.,,fergot to tell ya,,,they bought the whole "pulling unit" so all they know is that it cost them $360,000.00 for the motor,,,and everything "connected" to it,,,and they said its jus a small 1 ,,,but they also said,,it already (they've had for 8 months) paid for itself on savings from fuel,maintenance ,ect. and also its WAY faster then their old unit. hehe ;)
  3. Kaptin-Jer
    Kaptin-Jer Semi-Pro
    $360,000.00. Let me sleep on it and I'll get back to you.
  4. TripleCrownNC
    Likes: 2, Points: 0, Legacy Rep: 27
    TripleCrownNC Junior Member
    Ayyyyyyyyyyyyyyyah, bingo, much much better!
  5. the1much
    coolz hehe ;)
  6. the1much
    oh,,,,and which "bingo" was it?,,reducer or wax? hehe ;)
  7. TripleCrownNC
    Keep ya posted on it as it goes, thanks for keeping me going. I was getten close to caven in.
    I know from experience on other problems, maybe not over yet, hehe
    Heavy dose of meds tonight.(-;
  8. TripleCrownNC
    I think it was the rags. I got new lint free rags (the others were not lint free). I did a heavy wet alcohol wipe 2X, then a new tack rag. So really only thing I did different of real significance was the new rags and maybe a little more attentive on the tack wipe (slightly more pressure and being sure the cloth was flat on the surface).
    It aint perfect but I can live with it, much better.
    This experince just ramped up the details on all fronts, being very carefull at every step.
  9. TripleCrownNC
    Told ya I had the right reducer.
  10. the1much
    hehe,,,good fer ya,,hehe ;) ,,,you'll be back hehe ;)
  11. TripleCrownNC
    Thinken more to it just yet?
  12. the1much
    no i think you got it,,,whatever you did this last time,,,DO IT AGAIN hehe ;)
  13. Landlubber
    Landlubber Senior Member
    Good one.
  14. TripleCrownNC
    I also presoaked the brush in reducer then shook it out before I started. Hope I can do it again.
  15. Kaptin-Jer
    Kaptin-Jer Semi-Pro
    Do we get our consultant fees now??
