Rotating adjustable hydrofoils
Discussion in 'Hydrodynamics and Aerodynamics' started by mij, Nov 29, 2013.
  1. tspeer
    Likes: 290, Points: 83, Legacy Rep: 1673
    tspeer Senior Member
    It worked for the AC72s. It should work at model scale.
  2. Karl Wittnebel
    Likes: 3, Points: 0, Legacy Rep: 27
    Karl Wittnebel Junior Member
    Nice. Thanks for sharing.
    I only mention it because you talked about the cost being significant. Those figures seem fine for production stuff, but for what you are doing I don't get it. I would do unproven concepts in wet layup, cut one-off female tooling, and put it in the autoclave since you have one available.
    Exchangeable tips seem sexy, but I'm guessing the next advance will be in controlling the foil.
    If you are still in a sharing mood, I am curious about the bending moment at the hull exit and the foil thickness there.
  3. mij
    Likes: 3, Points: 8, Legacy Rep: 17
    mij Junior Member
    After some searching I found the image below:
    Was the axis around which the foil pivoted at the perforation through the base of the hull?
  4. Baltic Bandit
    Baltic Bandit Previous Member
    Dunno - I think that's the speculation and that makes sense from a load perspective
  5. Karl Wittnebel
    The rule prohibited the foil from translating at the hull exit. So yes that was the pivot, more or less, presumably. Some sort of spherical bearing or a gimbal.
  6. tspeer
    It was somewhat above the bottom of the hull on 17. This was because of the curve of the "elbow" in the foil and the need to retract the foil to within 500 mm of the bottom. There was a sliding seal that moved with the foil to avoid having a big open cavity. The Design Rule required the lower bearing to be fixed, but there was translation of the board & case away from the lower bearing.
    Other boats have used a torpedo-like fairing to put the axis at the bottom of the boat for canting keels.
