RORC Fastnet Race 2013
What isn't obvious from the entry list is that 5 of the multihulls racing in the Fastnet were all built in the same small village of Millbrook in Cornwall. My home for over 30 years.
Also built there was the first multihull to officially race in the Fastnet, one of my 35ft Banshee designs
Nice historical detail adds colour to the event, Richard!
(One day you must tell us one day how you avoided being kidnapped by Barbary corsairs.)
I thought Corsairs were built in Vietnam not on the Barbary coast?
Richard Woods
Thanks Riva.com is not loading. Video not in english so not much help. I would question how successful it would be. My experience is, if the mast is not plum then when you change tact the boat does not respond to optium on one of the tacts. So how will he get the mast plum for all sailing conditions especialy in gusts or variable winds on the same tact apart from feel and boat speed. Also addition worry re blocks exploding and rigging lines stretching so a mark on the lines will be ever changing. No stretching on hydraulick systems. Will all that give increased times over all?
Tried to get the sponsors to put a english translation button on the site but said they probably would not do untill the next Route de Rum because of costs. Does anybody know how much Approx the cost is per translation to have different Transation formats on a web site. Like a english website with French, German, Italian, Japo, and Chinese to increase visitors numbers and interest to a particular site. Corley have you investigated the cost for your blog. It could become world renowned if you had foreign translation capability.
OC
When the mast is not plumb but is leaning to leeward it certainly used to be a problem for the ORMA 60s. Standard long-race practice was to just dump the windward shroud hydraulic ram just before a tack to allow the mast to fall to leeward. The boat would then be tacked. This obviously saves the labour of pumping the rig to windward, but the boat became a real bear to handle once the rig canted to leeward.
PS Corley did you get that PM re the pics?
It looks on the tracker as though Prince de Bretagne Maxi has retired from the race.
And running for home.
I suspect his boat was a bit to light for the conditions. A bit more weight and he would probably still be racing.
Another frogie bites the dust. A shame he put a lot of thought into it.
OC
Banquepop and Spindrift have rounded now, between 2 and 3pm CET, Spindrift has their AIS on.
PdB on their site quotes Lionel Lemonchois saying their daggerboard was stuck in the down position; that appears to be the reason they abandoned.
Would like to follow the continuation, but have a flight to catch!
No press release yet that I have seen but Spindrift2 croaked home just ahead of Banque Populaire VII after the wind faded out in the final approach. They stayed in surprisingly close contact throughout the race and rounded Fastnet Rock within close range of each other. Oman Air MOD70 in third with Edmond de Rothschild MOD70 with some distance still to go.
Spindrift Racing press release:
http://www.spindrift-racing.com/201...aran-spindrift-2-wins-the-rolex-fastnet-race/
They crossed the line only seconds ahead of Banque Populaire VII after the wind faded out near the finish and the heavier Spindrift2 started losing ground to the relatively lightweight BPVII.
Correction it wasn't actually that close the gap at the finish was 22 minutes not sure why the press release reads as only seconds seperation.
The entry list has been published. Gitana 11, Prince de Bretagne Maxi and Spindrift Racing are entered with their MOD70 not Spindrift 2 (Banque Populaire V) maybe they did not have enough preparation time their last tweet mentioned that they were about to crane out BPV for a change of colour scheme and no word since.
Good to see some privateer multihull entries with a Corsair 31-1 D entered a Schionning waterline 1160 and a dazcat D1150.
https://secure.rorc.org/app/index.p...Hash=80a8429ebcb61f9d97413a96bd04f1ae1b32f7ee
Can't find Dazcat in the list of Mulitihulls only DAZZLA.
Did it withdraw.
OC
The Dazcats (Dazzla, Suenos) are still out racing the dazcat Drama Queen has finished you can see them on the tracker if you look in the vicinity of Lands End they are racing in the MOCRA multihulls category. The Schionning waterline is trailing Suenos.
Still can't find waterline on the tracker lists all divisions. SORRY TO BE A PAIN CAN YOU GIVE THE HYPERLINK TO THE INFO.
THANKS.
OC
If you open the tab and uncheck everything except the mocra multihulls it should show up and you can wind back the track.
Thanks. Obviously an old design. Do you happen to know the name off the boat. A couple off 40 footers mono hulls beat it home. It was for sale in 2008.
OC
