Rolly custom steel motorboat
Discussion in 'Stability' started by LeoKa, Sep 2, 2024.
  1. BlueBell
    Likes: 1,298, Points: 113
    No, not a boat broker although I do do boat deliveries, but that is also unrelated.
    I'm trying to help you resolve your dilemma.
    If it "might happen" I'm curious what boats you're considering.
    Maybe you're not really considering any other boats.
    If that really is the case then I think you should remove all the superfluous superstructure and
    return the vessel to its original design and roll period.
    No?
  2. LeoKa
    Likes: 11, Points: 8
    LeoKa Junior Member
    Correct. I am not considering any other boat. That is not why I am here.
    Spending a quarter million dollars on removing/rebuilding this boat to the original design, does not make financial sense. This is not a ' classic boat '.
    I am here on this forum to get ideas of a possible solution for roll reduction and stability improvements.
    BlueBell likes this.
  3. LeoKa
    LeoKa Junior Member
    Ad Hoc
    I know you are busy and I only want some confirmation from you.
    I have read this post several times and I am convinced that this is the only feasible solution for me, to address the rolling/stability issues. I am saying this because of my limited budget. This will still require investment and efforts, a good welder, a shop, and plenty of time; but I think it is doable. At least, this is the best way to go with a simple budget.
    Let me know if you agree and if there is any additional advice you have? Thanks.
  4. Tedd White
    Tedd White New Member
