Rivet replacement
Discussion in 'Metal Boat Building' started by Lampy08, Sep 8, 2010.
  1. Lampy08
    Likes: 2, Points: 0, Legacy Rep: 11
    Lampy08 Junior Member
    I was recently given an old riveted aluminium 16” Lund that was used hard by some loggers. She leaks quite a bit from several rivets and I’m hoping to get some advice about replacing them. Obviously I need to drill them out and put in over sized ones but are there any tricks or short cuts that would help?
    Also part of the reason the rivets worked loose is that the ribs have stress crack in the “V” . I’m thinking about putting some floors in and laying some plywood over them to help reduce the flexing any suggestions about that would help too.
    Dennis
  2. wardd
    Likes: 37, Points: 0, Legacy Rep: 442
    wardd Senior Member
    are they solid rivets or mechanically locking rivets with a pin in the middle?
    if solid center punch the head in the middle and use a drill the same diameter as the rivet and drill through the head only then use a drift pin to push the remainder out of the rivet hole
    an automatic center punch is handy
    if with a pin, try to use a drift pin to push the pin out or down and drill as above
  3. gonzo
    Likes: 927, Points: 123, Legacy Rep: 2031
    You can use a backing iron and a ball peen hammer to reset the rivets
  4. Lampy08
    ok this brings up two questions:
    Wardd, Is there a water tight mechanicly locking rivet (pop rivet) available for home shop type tools?
    Gonzo, are you sugesting tha I mearly tighten the existing rivet? Would that work? It would save a lot of time
    Dennis
  5. wardd
    wardd Senior Member
    http://www.alcoa.com/global/en/products/product.asp?prod_id=804
    but special rivet setters may be needed
    resetting may work but the holes may be oblong and or over size from vibration and wear and may loosen up again
    my knowledge of riveting is from aviation and boats may have different wear characteristics
    but removing the rivets will give you the chance to examine the holes for radial cracking and thinning of the metal under the rivet head
  6. gonzo
    Small boats are not as critical as airplanes. I have fixed a really bad boat, used for commercial crabbing, with a laminate of penetrating epoxy and 12oz cloth.
  7. Lampy08
    Some one tried epoxy and glass on it before and it is peeling off, nearly all peeled off really. I was looking at it a little closer this morning some of the rivets I can wiggle with just one finger. I think drilling out and replacing is best option. Now I have to find some stock to make rivet out of, or rivets for sale. Thanks for all your help folks.
    Dennis
  8. wardd
    wardd Senior Member
    go to a small airport and ask where you can get what you need
  9. alan white
    alan white Senior Member
    What I say too. Use a friend to buck the other side. Something about three pounds to buck them, like a sledge hammer head.
  10. wardd
    wardd Senior Member
    rivet guns and rivet sets and bucking bars don't cost much
    an air hammer about $50 and set less than $10
    and a round piece if 1" bar 6" long
  11. welderbob
    Likes: 1, Points: 0, Legacy Rep: 25
    welderbob Junior Member
    Mc Master=Carr sells rivets and setting tools
