RIB - Dive Boat - First Boat Build - Help Please!
Discussion in 'Boat Design' started by CodeS, Jan 25, 2020.
  1. CodeS
    Likes: 2, Points: 3
    CodeS Junior Member
    So, I want to build a boat. My main trouble is that I don't have much boating experience so I don't know what boat is going to be best for me.
    I have a pretty well equipt fabrication workshop, so from a construction standpoint I'm good to go.
    Let me tell you about a few of my requirements, and then what I am currently thinking. Here is a list:
    - Be light to tow long distances (as it will be mainly used on trips away up/down the NSW coast)
    - Fit 3 divers (+) with heavy, technical diving gear.
    - Be able to travel offshore, in NSW Australia, upto 20km trips each way (without having to wait for the perfect day).
    Currently I am thinking a 5-6m Aluminium RIB with hard foam collar with a 90hp + outboard. I am thinking a hard foam collar is going to be the easiest thing for me to build.
    So my questions are:
    * What would you build (with photos and rough measurements/key design points if at all possible)?
    * What would something like what I describe weigh?
    * Am I heading in the right direction?
    * Any questions I haven't asked/more info needed?
    Thanks in advance.
    CodeS
  2. Mr Efficiency
    What do you mean by a "hard foam collar" ? I noticed the title says "RIB" which I assume is "rigid inflatable boat", do you mean a foam collar instead of inflatable ? I expect you won't be much short of 2 tons towing weight with a boat capable of handling three divers and their gear, offshore. First thing to consider is the towing capacity of your vehicle.
  3. CodeS
    Likes: 2, Points: 3
    CodeS Junior Member
    Yes that is indeed what I meant, please excuse my ignorance. I have 3500kg towing capacity on my car but was hoping to not need anywhere near that to reduce wear and tear/fuel costs.
    Thanks for the response.
  4. Mr Efficiency
    bajansailor likes this.
  5. TANSL
    Likes: 971, Points: 123, Legacy Rep: 300
    Maybe something like that might interest you.
    Main Particulars:
    LOA = 5.26 m
    LH (hull) = 4,394 m
    Lbp = 3,904 m
    Lwl = 3,926 m
    Bmax = 2,590 m
    Bwl = 1,670 m
    Draft full load = 0.330 m
    Disp full load = 1100 kg
  6. BlueBell
    Likes: 1,306, Points: 113
  7. gonzo
    Likes: 2,389, Points: 123, Legacy Rep: 2031
    A 6 meter RIB or one with a hard collar is going to be small for three divers with technical gear. We use a 20' (6m) aluminum jon boat for commercial diving in protected waters and it is cramped. The collar will probable take 30% of the interior space. I assume you want to build a boat for the experience of it and not to save money.
  8. Mr Efficiency
    Certainly the desire to be creative is admissible to some extent, but if the main game is the diving offshore, you need a proven hull design. There are still a few of these old things around with dive doors, and with judicious selection ( they are getting old) around hull condition and engines, you have a boat that will completely eclipse the performance any 6 metre vee-hull offshore. I'm not au fait with the preferences of divers re inflatables or "soft" collared boats vs "hard" boats with dive doors, though.
  9. CodeS
    Likes: 2, Points: 3
    CodeS Junior Member
    Yes going for an alloy build as a preference, unless there is a lighter way :)
    I had looked at the Specmar boats in the past, my trouble was trying to get an idea on final weights.
  10. CodeS
    Likes: 2, Points: 3
    CodeS Junior Member
    Thanks for the image TANSL, yes that is the sort of information I was after.
    It looks like there is an inboard on that design? Is roughly that included in the 1100kg? I steered away from an inboard due to additional weight considerations, although it would make for easy access from the rear. I'd probably be keen to keep the internal area a bit more clear also, opting for standing/a small fold away seat with a minimalist dash.
  11. CodeS
    Likes: 2, Points: 3
    CodeS Junior Member
  12. CodeS
    Likes: 2, Points: 3
    CodeS Junior Member
    Yes, I do want to build it for the fun of it and also so I get things the way I want them.
  13. CodeS
    Likes: 2, Points: 3
    CodeS Junior Member
    Yes I have been on a number of boats similar to that, what sort of tow weights do they get?
  14. CodeS
    Likes: 2, Points: 3
    CodeS Junior Member
    I have been loving the look and design of the 'life proof boats' range like attached. As I understand they use a foam collar vs fabric tubes. I'd only be able to budget for a much smaller version however (which they don't build).
    Anyone have any idea on towing weight on a 5-6m version of these (even an educated guess)?
  15. TANSL
    The boat of post # 5 has a waterjet type propulsion because it was thought that it would be safer for divers. The stem, somewhat higher than normal, allows attacking waves of greater height. The total length, 5.26 m could be increased very easily to 5.86 m although the Bwl / Lwl ratio would be somewhat small.
    @CodeS, displacement full load is 1100 kg. If you would like more information, please send me a PM.
    CodeS likes this.
