DennisRB
Senior Member
- Joined
- Sep 21, 2004
- Messages
- 1,270
- Reaction score
- 28
- Location
- Brisbane
This seems to be all the rage right now and I have to say it looks cool. How do reverse bows affect the performance of the boat? I guess there are 2 scenarios you need to look at. My thoughts.
Imagine a 40 foot cat with plumb bows as a base example.
1: Say you design that 40 foot cat with reverse bows with LOA still 40 foot. Compared to a plumb bow you are loosing buoyancy above the water line. But also loosing weight and windage up the front. So yeah it should be faster with less weight and windage.
2: Instead of loosing a couple of feet of deck area and buoyancy at the bow, you then extend the bows a couple of feet at the waterline and fair the lines up to the top of the original stem. This would give more buoyancy and a longer water line for the minimum amount of weight. So in most conditions it will be faster as it has a longer water line and a better length to beam ratio by way of adding the minimum amount of weight.
Nose diving. Which of these 3 cats would be have the most tendency to nose dive or pitch pole? I would say cat 2 would be the least likely with more waterline and extra buoyancy. Cat one has less buoyancy but the shape of the bows do not lend them selves to burying themselves as the reverse bow has the perfect shape for "cutting" its way back up. Once the deck of the plumb bow version goes under the deck will act kind of like a foil which will be hydrodynamically opposed to coming back up due to the weight and force of the water pressing down on it.
Thoughts?
Thoughts?
