retainer nut
Discussion in 'Inboards' started by mikealston2428, Feb 23, 2015.
  1. mikealston2428
    Likes: 1, Points: 18, Legacy Rep: 10
    mikealston2428 Senior Member
    Hi guy's,
    I have a mercruiser mc1.
    The u joint retainer nut has corroded away on the bottom.
    What is the removal and installation procedure to replace it.
    Thanks
    Mike
    Likes: 948, Points: 123, Legacy Rep: 2031
    Are you talking about the nut that holds the splined shaft to the upper gear? If that is corroded, how do the gears look?
  3. powerabout
    Likes: 63, Points: 48, Legacy Rep: 719
    powerabout Senior Member
