Note: This feature may not be available in some browsers.
i want to change all the plywood on the bottom, now it has a 5 mm 5 strands of plywood, and i want to put 5 mm okoume covered with 32 strands of 400 g fiberglass with poliesteric, and the upper part will be covered with mahogany 8mm thick, and then also covered in clear epoxy.
3 layer plywood is not as strong as 5 layer plywood. I would not trust 3 ply on my hull.this is the bottom? my question is originaly it has 5 mm plywood in 5 strands..it will be ok if i replace it with 5mm 3 strands marine grade okume?
Why gelcoat and paint? Most gelcoat or paint.or better i should put 10 mm on bottom??
yes i meant polyester resin with gelcoat and then painted..
