I contacted a bracket manufacturer and sent some pictures , he said the transom would need significant reinforcement to to support the stress of outboard conversion and even with that done, the stringers appear to be too light and would likely be a problem as well . his recommendation would be to repower it with a sterndrive . I checked out the the mercury outboard, pulled the plugs, plugs all looked good. oiled the cylinders. it had been in storage for over 20 years. the wiring and fuel lines are in poor condition, it is stuck in forward drive gear, lower unit oil is clean no water intrusion or metal shavings, fuel pumps shows some external corrosion. compression is 90 psi for all cylinders. it does have spark. will likely need a fuel pump, carb kits, wiring replaced , water pump impeller and some work on the lower unit shift mechanism. I am wondering what this outboard is worth if I wanted to sell it. I would have to spend quite bit of time and a few hundred dollars in parts to get it in running condition.
