Note: This feature may not be available in some browsers.
Maybe WD-40, pour a little into it every day, it's cheaper by the gallon . . ? - (Walmart CA $ 25). . . . take an extremely light penetrating oil and let it sit in the cylinders for several days . . . .
Maybe take away the compression, and try a makeshift oversized oil filter wrench on the flywheel . . ?Now have to figure how turn engines manually.
Meant there was till the pistons and rings are loose, in case they are stuck, so lubrication only came in second place here.Maybe WD-40, pour a little into it every day . . . .
My experience from reading these forums is that makes far less than 1 ‰, so no reason for worries I think, and your main message that it can cause problems turned out to be right, so I'll guess that's why WD-40 also offers an Electrical Contact Cleaner, which corresponds to your advice to use such a product.My bad . . . .
By now I'll guess we're all anxious to know about that . .So, did it fire ?
