Thanks.
But, again, it is just series of numbers and reference to where the numbers/data is coming from to provide any meaningful commentary.
You are being blinded by the numbers and not focusing on the objective.
Dear Ad Hoc, thanks for your interest...
I'm going to try to explain again what I was trying to do.
First, a simple check of the Muller-Graf method with a minimum of data taken from his own work.
What do I need to calculate the resistance? Only three figures, the angle of the dead rise in midship, the angle of the transom wedge and the L/B ratio. I took those 3 figures from the work and make a simple spread sheet, and I had a great surprise when I got negative values of the Residuary/Weight ratio coefficient...
It's as simple as that. Do not try to do an in-depth study, for that is the next stage once the accuracy of the method has been verified. I copied the coefficients from the work, replaced them in the formula, and.... Get negative figures
Second. I always try to start from the simplest to the most complex and seeing partial results. So, if there is a problem, it is easier to find and solve.
Third. In this particular case, I can't get pass over the first part. I took the values directly from the work, to save time, I looked in different places to see if there are published works using this method to calculate the resistance, but unfortunately I could not find any. That's why my post in the forum, perhaps, someone who works with this method, using my data could check my results, I din't try to make any speculation. My spreadsheet is open to anyone who wants to see and review it. The only thing I ask in return, if you find an error, to make it notice me
Fourth and last. My goal is to calculate the resistance of a catamaran with chines, I don't know how precise the application of other methods will be. This seemed to me the optimal one, since it was developed for that type of forms.
And thanks again for trying to help me (sorry for the extension of reply)
