Resistance, back to basics
Discussion in 'Hydrodynamics and Aerodynamics' started by Lietuvis, Feb 23, 2018.
  1. Lietuvis
    Lietuvis Junior Member
    Hello. I'm doing CFD simulation of the hull and i'm getting outputs for x pressure force, y pressure force, z pressure force and shear forces. Maybe my question will sound stupid, but should i consider z axis pressure (or even y axis) for resistance? As i understand some of the thrust will be used to lift hull upwards (extreme example of this would be hydrofoils or planning hulls), so total resistance should be x pressure + z pressure - displacement + shear forces? Or is it just x pressure and shear forces?
    Note: z is pointing downwards (or maybe upwards)
  2. DCockey
    DCockey Participant
    Do you have an engineering or physics background? Do you understand the concept of forces as vectors?
  3. Lietuvis
    Yes i have. I just never thought about hydrodynamic lift in displacement ships and its influence for resistance.
  4. patzefran
    Likes: 68, Points: 28, Legacy Rep: 10
    patzefran patzefran
    So you understand you can't add force components on different axis !
  1. Joonatan
  2. Alexanov
  3. mc_rash
  4. Simme_swede
  5. Furkan
  6. Ousmane
  7. zstine
  8. zstine
  9. Furkan
  10. Leo Ambtman
