required engine power for displacement/ semi displacement and planing boats
Discussion in 'Boat Design' started by M.Raven, May 27, 2015.
  1. M.Raven
    M.Raven New Member
    Hello.
    I am looking for a tool(s) that could be able to predict the required engine power for displacement/ semi displacement and planing boats?
    I have seen spreadsheet for planning boats from Dingo. But I can imagine it is only valid for planning boats.
    Could you please help me regarding this?
    I also have no access to this paper `The Prediction of Power Performance on Planing Craft` by Hadler. Does anybody could provide it to me?
    Thanks in advance!
    Cheers,
    email
    Ravanan.mahmoud@gmail.com
    Likes: 2,233, Points: 123, Legacy Rep: 2031
    This is an old time nomogram that works well:
  3. nzboy
    Likes: 6, Points: 18, Legacy Rep: 36
    nzboy Senior Member
    prop calculator
    http://www.vicprop.com/calculator.htm
    this prop calculator might be of a help you will have to copy link as I cant get it to go live
  4. baeckmo
    Likes: 832, Points: 113, Legacy Rep: 1165
    baeckmo Hydrodynamics
    Thanx for the interesting nomogram, Gonzo. Where/what is the source?
  5. gonzo
    I copied it years ago from "The boat data book" by Nicholson
  6. M.Raven
    M.Raven New Member
    Displacement hull
    Gonzo ,
    Thank you so much for your help.
    Do you have a spreadsheet (or any other useful tool) for displacement hull that I could you it to check my result with that?
    I used this graph and also the excel sheet of Dingo but it is not accurate.
    Thank you.
    Cheers
  7. YotaTruck
    YotaTruck Junior Member
    I have been using these calculations to play around with a boat I drew up recently. It is a planing hull, but there are displacement and semi-displacement calculations in here as well:
    http://www.westlawn.edu/news/WestlawnMasthead06_June08.pdf
    I was actually just going to start another thread on this when I saw your post. I'll still do a separate one so as not to confuse the discussions.
