Repower a 43' Planing hull houseboat with diesel sterndrive.
Discussion in 'Diesel Engines' started by Wado, Jan 1, 2011.
  1. Brian@BNE
    Likes: 13, Points: 18, Legacy Rep: 151
    Brian@BNE Senior Member
    Seems good advice to me re: engines. I'd look at a Zeus drive instead of a traditional sterndrive leg. Depending on space, which could be generous on a houseboat, you may be able to engineer one that can be raised out of the water when not in use.
  2. kapnD
    Likes: 131, Points: 43, Legacy Rep: 40
    kapnD Senior Member
    I'm afraid the short answer is NO, the reason, as mentioned above is inability of gears to handle the torque.
    The Cummins 6b is a great motor, but makes its power at way lower revs than a comparable yanmar or volvo, and is a notorious destroyer of stern drives.
    Volvo is making new sterndrives that are said to be capable of diesel torque, however I wouldnt jump on the bandwagon just yet, but let the dust settle until it becomes a proven product.
    Depending on how much use the boat will actually get, gassers may be much cheaper in the long run anyway, you just have to pencil out the alternatives.
