Replacing wooden bulk head on glass boat
Discussion in 'Fiberglass and Composite Boat Building' started by LEASEGUY, Nov 27, 2006.
  1. LEASEGUY
    LEASEGUY Junior Member
    What to use Replacing wooden bulk head on glass boat
    I have an older silverton glass hull, glass over wood upper, the bulkhead that seperates the interior from from the aft deck is soft. What is the best material to replace it with and where can i get it. I need to make two panels each
    3/4 thick 6'6" x 48". White would save re finishing.
    Love this site, thanks to all for you very interesting and insightfull posts ..
  2. buckknekkid
    Likes: 4, Points: 0, Legacy Rep: 37
    buckknekkid Senior Member
    I have just completed it on my 36 trojan, best bet I found was a company called Space Age Synthetics
  3. LEASEGUY
    Thanks for the info, did the surface require finishing? and what density did you use? easy to cut?
  4. lacasmarine
    lacasmarine Junior Member
    I would use marine grade plywood.
    and finsh any way you like.
  5. LEASEGUY
    Thanks lacasmarine ,but too labor intensive, I want the finish to look like smooth white gel coat
  6. LEASEGUY
    Thanks BUCK,
    I looked at their site and emailed them for price info and it wasn't 5 minutes before they were on the phone! Thanks
  7. buckknekkid
    the surface is sanded, so you have to smooth out the joints regardless. the hatch is epoxied and needs to be faired big time.
  8. naturewaterboy
    naturewaterboy Steel Drum Tuner
    Bucknekkid,
    Is that Space Age Synthetics board on the floor in your pict? Which type and thickness did you use?
  9. buckknekkid
    Unfortunately not
    While speaking with Space Age and planning the project, I ran out of time and then of course was about to lose my storage so we went the old plywood and epoxy route. With this said I am still stuck with fairing this year and finishing inorder to throw out the cheap carpet I put over the sole last year. It would have been much easier using their product.
  10. buckknekkid
    Well we are back into it again
    sanding and fairing STILL
  11. fiberglass jack
    Likes: 16, Points: 0, Legacy Rep: 95
    fiberglass jack Senior Member
    when your done that you can come over and do this one for me,
  12. fiberglass jack
    try this again
  13. buckknekkid
    We are going to be awhile
    Its time to bring out the chain saw for that puppy.
  14. buckknekkid
    here is a few more pics
    these are for the guys on Trojanboats dot net
  15. trawler builder
    trawler builder Junior Member
    i am again going to recommend COOSABOARD , it is ridgid like plywood and after it has been put in place and glassed will leave you with a straight surface requiring the least amount of fairing . Fiaring isn't too hard using a product like f-26 ,it sands easy and will give you a nice surface to paint .
    tb ( not a coosaboard salesman just like their product)
  1. teneicm
  2. xiphas
  3. midcap
  4. Skua
  5. 9986mkoh
  6. dbstormchild
  7. DennisRB
  8. Scrapper
  9. minib78
  10. LewisHB
