sdowney717
Senior Member
- Joined
- Nov 13, 2010
- Messages
- 1,600
- Reaction score
- 118
- Location
- Newport News VA
They are so close to the block, I can't fit a wrench on them, and the shell spins.
I was thinking maybe some large water pump pliers and squeeze super hard might turn them out. And the starboard engine, this is hard to reach. They sit under the exhaust manifold. Worst thing, I will have to remove manifold and cut them off with a sawzall.
Most likely they are original to 1970.
They are Sierra dual station. I bought new ones and then coated the shell with JB Weld, plan to also paint them.
To prevent them being impossible to install or remove, I got 1/8" extenders off Amazon. These are 304 SS.
I bought SS as I thought what if they were brass and got hit, like maybe would snap off.
SS has a higher electric resistance, but the currents here are super low. And this is a good size chunk of SS. They will thread into cast iron block, and the sensor metal is steel, hope they don't leak. I would not use teflon tape, but I might use rector seal T Plus 2, which I don't think would block electric connection.
RectorSeal T Plus 2 in. 4 oz. Teflon Pipe-Thread Putty/Sealant 23633 - The Home Depot
Amazon.com: DERPIPE Forged Reducer Adapter Fitting - Stainless Steel 304 Reducing Pipe Connector, 1/8" NPT Female x 1/8" NPT Male (pack of 2) : Automotive
