Hello everyone, I figured I would not start a new thread for this as it is just another step in this process that I hope you all can help me with.
I am in the process of "rebuilding" a 305 for a coworker's boat. I was just able to get it just about all torn down to just the block. The reason for this teardown is that the engine was not winterized correctly and cracked the block on both sides (just above the engine mounts). The block is a complete loss and at this point, I think it might be better to just find a 350 and put the intake, fuel pump, exhaust manifolds, and other marine specific things on the replacement engine. That all being said, on another site I am reading that some of these engines were designed to run reverse of a car engine, as well as the marine cam is different than a car cam.
The boat is a big old cabin cuddy (I'm a high school shop teacher, not a marine person)? Has a Mercruiser of some type. If I get a different engine do I need to figure out the other firing order to achieve reverse running, and change the cam as well? I know I am asking a lot with almost no information but hopefully, someone can help me.
Thank you,
Also, who would I talk to about OMC sterndrive things? I made a mistake and bought one a couple years ago...
Thank you again,
Ian Schilf
