I am in progress of a 100% rehab of a 30' Rybo Runner CC and changing from inboards to outboards hence I now have multiple below waterline holes, shaft pockets and rudder shafts to seal. I seem to have numerous concerns or looking for verification of my plans.
Shaft pockets - I assume cut out completely (3" x 12"), fill with either plywod or composite, glass both sides; What fill is best, type of glass, sealant? do I need a larger backer plate on inside (screwed, glassed)?
Thur hull holes ; Assume fill with plywood plug (type??) what is best sealant, glass both sides, do I need a larger backer plate in inside? holes are ~2"
Rudder shafts; holes are ~1.5" with 4"x4" plates on top which seem to have warned glass below, should I cut out the entire section or just fill the hole
General; What is best fill plywood? type, other woods, composite plastic
Type of resin, type of glass
Sealant for repair?
Top backing plate?
Have some other above water repairs, exhaust holes, air vents which I assume will be repaired in similar manner
THanks for the advice in advance, if needed I can post pics of repair areas
THanks
Tom
Sealant for repair?
Top backing plate?
THanks
Tom
