Removing tunnel hull from aluminum job boat
Discussion in 'Metal Boat Building' started by Shawn_Laughlin, Jul 17, 2019.
  1. Shawn_Laughlin
    Shawn_Laughlin Junior Member
    How much do you think it would cost to take a boat that has a tunnel reverted back to flat?
    It’s a 1648 welded aluminum boat. A guy is putting a surface drive on it and their is no use and actually it hurts performance from what I understand and wants me to cap of the tunnel and I’m not sure what to charge. I don’t have any experience with surface drives only regular outboards.
  2. baeckmo
    Likes: 832, Points: 113, Legacy Rep: 1165
    baeckmo Hydrodynamics
    What kind of tunnel are you talking about? Give us some pictures first, then we may discuss your options.
  3. Shawn_Laughlin
    Just a simple 18” at most long tunnel similar to this.
  4. kapnD
    Likes: 539, Points: 113, Legacy Rep: 40
    kapnD Senior Member
    It’s just a matter of welding a plate over a void, and cutting off projection, pretty straightforward, I’d say.
    You’re a pro welder, right?
    No different than any other welding job, bidding it is time, materials, profit.
  5. Shawn_Laughlin
    Yes sir kapnD been welding full time since I was 16 and it was aluminum I started with. It actually took me about 8 hrs but that includes flipping the boat which took a good bit of time bc I have no forklift or crane and I was by myself. Wasn’t too bad though.
  6. BlueBell
    Likes: 1,221, Points: 113
    So, 8 hrs and what did you charge?
