Hello.
I am looking for tips and information on proper equipment to finish an aluminum hull.
At this stage the hull has clear scratches/swirl marks, as you can see in the photo's attached.
The information I got was to continue with a rotary sander (eccentric) and 50, 80, 120 grit paper.
We started of with a Festool RO 150 FEQ and 40 grit sandpaper, but this turned out to be too course.
Almost identical depth scratches/swirls.
Going directly to 80 grit sianet 150 discs, does not seem to go deep enough for a first step, but would probably do a good job further in the process, before than moving on to progressively finer grit.
It seems it needs a step in between the current level of finish (from the builder).
any input is welcome.
Philippe
SV Pen Gwyn
Philippe
SV Pen Gwyn
