Relation between machine power and cargo weight
Discussion in 'Boat Design' started by toda, Feb 13, 2008.
  1. toda
    toda Junior Member
    Have any document or suggestion about relation between machine power and weight of cargo for cargo ship (under 10000T). Could any one give me advice about it. Thanks in advanced.
  2. Kay9
    Likes: 26, Points: 0, Legacy Rep: 279
    Kay9 1600T Master
    huh?
    What exactly is it your in need of??????
    K9
  3. Jango
    Likes: 7, Points: 0, Legacy Rep: 63
    Jango Senior Enthusiast
    For a given Speed, Required Power is proportional to Gross Weight. i.e.
    To maintain a given speed, if Gross weight increases by 25%, H P must also increase by 25%
    Hope this helps,
    Jango
  4. Kay9
    Kay9 1600T Master
    Thanks Jango, I couldnt figure what it was he was asking.
    K9
  5. toda
    toda Junior Member
    Thanh you very much for your advice Jango. That 's exactly what I want.
  6. ted655
    Likes: 14, Points: 0, Legacy Rep: 122
    ted655 Senior Member
    shouldn't there be more?
    A displacement hull, carrying a gross wt of ??? requires ??? HP, to achieve a speed of ??? Kts sustained.
    :confused: A formula to get a basic ratio between gross tonnage & HP, THEN the need to increase the load to HP ratio of 1:1?
    For every ton, it takes ?? HP, to go ?? Kts.
