I was also thinking about some simmilar system to make the dipping lug a bit easier to tack to short handed crew. Do you think that the lower part of the yard could be pulled behind the mast without putting some slack in the halyard first? If so, the peak halyard would be needed to prevent the yard crashing down.
Hi, Igor.
When sailing, there are only three lines controlling a dipping lug.
Starting from the bow, we have the tack line. That holds the tack (the lower forward corner of the sail) to the bow.
Next, we have the halyard. This line raise and lowers the sail by raising and lowering the yard.
Finally, we have the sheet line. This controls the angle the sail is set at.
In order to swing the yard behind the mast, two of these three have to be slackened.
The two I would slacken are the tack line and the sheet line. Once these two are slackened, the yard is free to pitch up higher and higher until it is nearly vertical and its lower end can be pulled behind the mast.
Once that is done, it is relatively easy to slip the lower end of the yard onto the leeward side of the mast. Then, the tack line and the sheet line can be tightened.
In order for this all to work, the yard must hang from a pendant that is attached to loop that goes around the mast (the parallel). And this loop is attached to the halyard.
So, when the halyard is hauled, this loop is raised, and it raises the pendant which raises the yard. This pendant must be about 2 mast diameters long, if the mast is round, and 3 diameters long, if the mast is square.
This is to insure the yard has enough room to stand behind the mast.
It is theoretically possible to have all the controlling lines led after.
But there would be a lot of them.
2 for the port and starboard tack lines,
2 for the port and starboard yard dipping lines,
2 sheet lines, port and starboard, and
1 halyard.
Operating this sail would be similar to operating a Yankee, jib and staysail on a cutter.
