Regulatory definition of ship breadth
Discussion in 'Boat Design' started by e.m.milad, Dec 5, 2016.
  1. e.m.milad
    e.m.milad Junior Member
    hi every body!
    I had an odd case with ship terms and definitions I want to know regulatory definition of ship breadth in ships with flare or Some Thing like that as picture below :
    which one is the breadth of the ship according to ICLL 69 or SOLAS
  2. TANSL
    The best thing you can do is read the rules you want to apply. I know it is not a pleasant task, but to apply a regulation it is important (essential) to know it.
    All the regulations, in the first pages, explain how to measure the dimensions of the artifact to be calculated.
  3. e.m.milad
    Hi TANSL !
    Thank you for your kind response
    I read those regulations many times! but this is a controversial question !
  4. Ad Hoc
    SOLAS is very clear:
    "...Breadth of the ship is the extreme width from outside of frame to
    outside of frame at or below the deepest subdivision load line..."
    Part A reg.2
  5. e.m.milad
    So which one is the breadth?
    The B at deck? according to flare ( or rectangular thing!) ?
    or
    the B at side neglecting the flare?
  6. Ad Hoc
    :rolleyes:
  7. RAraujo
    Likes: 22, Points: 18, Legacy Rep: 114
    RAraujo Senior Member - Naval Architect
    On the other hand according to ITC69 (you are referring to ICLL 69 which I do not know - it is ITC69 or ICLL66):
    Breadth - The breadth is the maximum breadth of the ship, measured amidships to the
    moulded line of the frame in a ship with a metal shell and to the outer surface of
    the hull in a ship with a shell of any other material.
    and according to ICLL66:
    Breadth. Unless expressly provided otherwise, the breadth (B) is the maximum
    breadth of the ship, measured amidships to the moulded line of the frame in a ship
    with a metal shell and to the outer surface of the hull in a ship with a shell of any
    other material.
    As Tansl mentioned the definition should be in the corresponding instrument as different instruments might have different definitions.
  8. e.m.milad
    Thank you very much Sir
    I meant International Convention on LoadLines 1966
    according to the definition the largest one is the breadth??
  9. RAraujo
    Yes, it should be the maximum breadth measured at a section midway between the perpendiculars (according to the Length definition of the ICLL66). Note the differences in measurement for different materials...
